<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document" width="90" x="112" y="75"> <parameter key="text" value="delta gamma beta alpha delta eta alpha "/> </operator> <operator activated="true" class="text:cut_document" compatibility="5.3.002" expanded="true" height="60" name="Cut Document" width="90" x="112" y="165"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="text" value="(\S+)"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="179" y="30"/> <connect from_port="segment" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.3.002" expanded="true" height="76" name="Documents to Data" width="90" x="246" y="75"> <parameter key="text_attribute" value="text"/> <parameter key="add_meta_information" value="false"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
