<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="7.0.001" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="rename" compatibility="7.0.001" expanded="true" height="82" name="Rename" width="90" x="246" y="34"> <parameter key="old_name" value="label"/> <parameter key="new_name" value="Promotion"/> <list key="rename_additional_attributes"> <parameter key="att1" value="Stats"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="7.0.001" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Promotion|Stats"/> </operator> <operator activated="true" class="r_scripting:execute_r" compatibility="6.5.000-SNAPSHOT" expanded="true" height="82" name="Execute R" width="90" x="715" y="34"> <parameter key="script" value="# rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) rm_main = function(data) { data$Promotion <- as.factor(data$Promotion) print(str(data)) logModel <- glm(Promotion ~ Stats,family="binomial"('logit'),data =data) return(logModel) } "/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Execute R" to_port="input 1"/> <connect from_op="Execute R" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
