<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.1.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.1.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.1.000-SNAPSHOT" expanded="true" height="68" name="Retrieve 123" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Local Repository/123"/> </operator> <operator activated="true" class="split" compatibility="7.1.000-SNAPSHOT" expanded="true" height="82" name="Split" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="split"/> <parameter key="split_pattern" value="x"/> </operator> <operator activated="true" class="filter_examples" compatibility="7.1.000-SNAPSHOT" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="34"> <list key="filters_list"> <parameter key="filters_entry_key" value="split_6.contains.35"/> </list> </operator> <connect from_op="Retrieve 123" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <connect from_op="Filter Examples" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75"> <parameter key="excel_file" value="rapidminer_split_text.xlsx"/> <parameter key="imported_cell_range" value="A1:B4"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="bla.true.polynominal.attribute"/> <parameter key="1" value="split.true.nominal.attribute"/> </list> </operator> <operator activated="true" class="split" compatibility="5.3.013" expanded="true" height="76" name="Split" width="90" x="180" y="52"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|split"/> <parameter key="include_special_attributes" value="true"/> <parameter key="split_pattern" value="x"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Multiply" width="90" x="315" y="30"/> <operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes" width="90" x="450" y="30"/> <connect from_op="Read Excel" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_port="result 2"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
