<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve svmthesis_original" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Local Repository/svmthesis_original"/> </operator> <operator activated="true" class="normalize" compatibility="5.3.008" expanded="true" height="94" name="Normalize" width="90" x="246" y="30"/> <connect from_op="Retrieve svmthesis_original" from_port="output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
=(B3-B$291)/(B$292-B$291)*(1-(-1))+1
