<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document" width="90" x="112" y="30"> <parameter key="text" value="<p> Thisisgood </p> <p> Thisisbad </p> <p> This <br> is <br> acceptable </p> <p> Thisisfine </p> "/> </operator> <operator activated="true" class="text:cut_document" compatibility="5.3.002" expanded="true" height="60" name="Cut Document" width="90" x="246" y="30"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="p" value="//h:p"/> </list> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.3.001" expanded="true" height="60" name="Extract Content" width="90" x="179" y="30"> <parameter key="minimum_text_block_length" value="1"/> </operator> <operator activated="false" class="text:extract_information" compatibility="5.3.002" expanded="true" height="60" name="Extract Information" width="90" x="313" y="120"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="result" value=" //h:p/text()"/> </list> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="segment" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.3.002" expanded="true" height="76" name="Documents to Data" width="90" x="380" y="30"> <parameter key="text_attribute" value="text"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
