No full download for 5.3.15?
MacPhotoBiker
New Altair Community Member
I'm running RM 5.3.013 on Linux Mint 15. When I check updates, I get a notice that the new version 5.3.15 is available. So I log in, and select the update for download and installation. At the end, I get a message that it was installed successfully, and I'm asked if I want to restart RA. When I click yes, RA is shut down, but does not restart itself. When I start it manually, the update is not being installed, I'm still running RA 5.3.013.
I then tried to simply download a new full version, but on SourceForge, 5.3.013 is the latest available version:
http://sourceforge.net/projects/rapidminer/files/1.%20RapidMiner/5.3/
Is there a way to get my installation updated properly? Or to the contrary, can I somewhere download the latest full version?
Thanks!
Thanks!
the automatic update probably only works if you use the RapidMinerGUI script, not when loading RapidMiner via java -jar. However, if you need to download the full latest version you can get it from http://community.rapidminer.com (there is also a link to the community site at the bottom of the normal http://rapidminer.com website).
Best regards,
Marius0
