Force Vs Displacement Graph in Hyperview
User: "NoorAlam_08"
Altair Community Member
Updated by NoorAlam_08
Hi Everyone.
Can anyone help me how can generate force vs displacement graph in hyperview.
I am doing a impact analysis in radioss but i am unable to generate the Reaction force vs Displacement graph.
Can anyone help me the process to generate force vs  displacement graph.
Regards
Noor Alam
1 - 4 of 41
    User: "PrasannaK"
    Updated by PrasannaK
    Kindly find the video link for your reference (demonstrate basic plotting in HV): https://www.youtube.com/watch?v=IdwBQ-YOIr8
    Since you are performing analysis here, you can load the result file (h3d) in HV/HG and plot the graph.
    Thank You
    User: "NoorAlam_08"
    OP
    Hi.
    I have generate Reaction Force vs Time And Displacement vs Time graph.
    But i need from these graph to Reaction force vs Displacement graph.
    Can anybody know how be find this graph.
    Regards
    Noor Alam
    User: "Sebastian_Karp"
    Updated by Sebastian_Karp
    if you have a base of curves DISP-vs-TIME and FORCE-vs-TIME, and would like to do a crossplot to get e.g. FORCE-vs-DISP, then I recommend one macro / function from the MVP Toolbar (btw I need to check MVP support for Student Editions). One of those:
    The function is defined in MVP as:
              function sync2y(c1x,c1y,c2x,c2y,flag)
                    min2c  = max(cat(min(c1x),min(c2x)))
                    max2c  = min(cat(max(c1x),max(c2x)))
                    ptsrangec1x = numpts(subrange(cat(c1x,min2c),min2c,max2c))
                    ptsrangec2x = numpts(subrange(cat(c2x,min2c),min2c,max2c))
                    if(ptsrangec1x >= ptsrangec2x)
                        newx = c1x[subrange(c1x,min2c,max2c)]
                    else
                        newx = c2x[subrange(c2x,min2c,max2c)]
                    endif
                if(flag == 1)
                    newy = lininterp(c1x,c1y,newx)
                endif
                if(flag == 2)
                    newy = lininterp(c2x,c2y,newx)
                endif
                    return newy
    The Macros using this function creates a new curve with these vector definitions:
    This way, not matching vectors are sychronized, compared to using the definition
    x=p1w2c1.y  /  y=p1w1c1.y
    as new curve, where e.g. an Offset of original curves would not be recognized. So the way described above should be the clean way to do this.
    Unfortunately I do not find a better documentation for this specific function. Hope this helps.
    User: "Rogerio Nakano_21179"
    New Altair Community Member
    Updated by Rogerio Nakano_21179
    Hi
    If you request the force and the displacement on the given node via /TH, you will be able to create the force vs displacement with HyperGraph.
    Please refer to the Radioss documentation of the keyword /TH
    Regards
