<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="advanced_file_connectors:read_xml" compatibility="7.0.001" expanded="true" height="68" name="Read XML" width="90" x="112" y="34"> <parameter key="file" value="C:\Users\user\Desktop\linearRegression.mod"/> <parameter key="xpath_for_examples" value="//object-stream/LinearRegressionModel/LinearRegressionModel"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="default[1]/attributeNames[1]/string[1]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/attributeNames[1]/string[2]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/attributeNames[1]/string[3]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/attributeNames[1]/string[4]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/attributeNames[1]/string[5]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/coefficients[1]/double[1]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/coefficients[1]/double[2]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/coefficients[1]/double[3]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/coefficients[1]/double[4]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/pValues[1]/double[1]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/pValues[1]/double[2]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/pValues[1]/double[3]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/pValues[1]/double[4]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/selectedAttributes[1]/boolean[1]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/selectedAttributes[1]/boolean[2]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/selectedAttributes[1]/boolean[3]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/selectedAttributes[1]/boolean[4]/text()"/> <parameter key="xpath_for_attribute" value="default[1]/selectedAttributes[1]/boolean[5]/text()"/> </enumeration> <list key="namespaces"/> <parameter key="use_default_namespace" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="default[1]/attributeNames[1]/string[1]/text().true.attribute_value.attribute"/> <parameter key="1" value="default[1]/attributeNames[1]/string[2]/text().true.attribute_value.attribute"/> <parameter key="2" value="default[1]/attributeNames[1]/string[3]/text().true.attribute_value.attribute"/> <parameter key="3" value="default[1]/attributeNames[1]/string[4]/text().true.attribute_value.attribute"/> <parameter key="4" value="default[1]/attributeNames[1]/string[5]/text().true.attribute_value.attribute"/> <parameter key="5" value="default[1]/coefficients[1]/double[1]/text().true.attribute_value.attribute"/> <parameter key="6" value="default[1]/coefficients[1]/double[2]/text().true.attribute_value.attribute"/> <parameter key="7" value="default[1]/coefficients[1]/double[3]/text().true.attribute_value.attribute"/> <parameter key="8" value="default[1]/coefficients[1]/double[4]/text().true.attribute_value.attribute"/> <parameter key="9" value="default[1]/pValues[1]/double[1]/text().true.attribute_value.attribute"/> <parameter key="10" value="default[1]/pValues[1]/double[2]/text().true.attribute_value.attribute"/> <parameter key="11" value="default[1]/pValues[1]/double[3]/text().true.attribute_value.attribute"/> <parameter key="12" value="default[1]/pValues[1]/double[4]/text().true.attribute_value.attribute"/> <parameter key="13" value="default[1]/selectedAttributes[1]/boolean[1]/text().true.attribute_value.attribute"/> <parameter key="14" value="default[1]/selectedAttributes[1]/boolean[2]/text().true.attribute_value.attribute"/> <parameter key="15" value="default[1]/selectedAttributes[1]/boolean[3]/text().true.attribute_value.attribute"/> <parameter key="16" value="default[1]/selectedAttributes[1]/boolean[4]/text().true.attribute_value.attribute"/> <parameter key="17" value="default[1]/selectedAttributes[1]/boolean[5]/text().true.attribute_value.attribute"/> </list> </operator> <connect from_op="Read XML" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
