Altair RISE
Nominate Yourself Now!
Wordnet
rfeigel
Is Wordnet supported in v. 6.5? If so, does anyone have clear, simple instructions for how to install it. I've installed it and pointed the dictionary to a folder where I've unzipped Wordnet 3.0. When I run it against a simple text file, I get no results or error messages. Any help is appreciated.
JEdward
Can you share your process for how you connected?
It works for me, was just using it 30 minutes ago alongside Extract Sentiment, Aylien, & Python (for Chinese) to create a hybrid multi-lingual sentiment classification system.
My next step will be adding ApacheSolr for improved tokenization, Moses
http://www.statmt.org/moses/
for a fallback 'translate to English' sentiment analysis and moving the Python script into a Java operator so it works faster.
rfeigel
Here's the script:
<process version="6.5.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="wordnet:open_wordnet_dictionary" compatibility="5.3.000" expanded="true" height="60" name="Open WordNet Dictionary" width="90" x="112" y="210">
<parameter key="resource_type" value="directory"/>
<parameter key="directory" value="F:\Data\Rapidminer 6.5 Repository\Wordnet 3\dict"/>
<parameter key="repository_folder" value="//6_5 Repository/Wordnet 3/dict/"/>
<operator activated="true" class="text:read_document" compatibility="6.5.000" expanded="true" height="60" name="Read Document" width="90" x="112" y="75">
<parameter key="file" value="C:\Users\User\Desktop\Test.txt"/>
<parameter key="extract_text_only" value="true"/>
<parameter key="use_file_extension_as_type" value="true"/>
<parameter key="content_type" value="txt"/>
<operator activated="true" class="wordnet:find_synonym_wordnet" compatibility="5.3.000" expanded="true" height="76" name="Find Synonyms (WordNet)" width="90" x="313" y="120">
<parameter key="use_prefix" value="true"/>
<parameter key="synset_word_prefix" value="syn:"/>
<parameter key="maximum_recursion_depth" value="1"/>
<parameter key="multiple_meanings_per_word_policy" value="Take all meanings per token"/>
<parameter key="multiple_synsets_policy" value="Take only first synset per meaning"/>
<parameter key="multiple_synset_words_policy" value="Take only first synset word"/>
<parameter key="concatenation" value="Concatenate result per synset"/>
<parameter key="keep_original_tokens" value="false"/>
<parameter key="keep_unmatched_tokens" value="false"/>
<parameter key="take_ID_instead_of_words" value="false"/>
<parameter key="work_on_type_noun" value="true"/>
<parameter key="work_on_type_verb" value="true"/>
<parameter key="work_on_type_adjective" value="true"/>
<parameter key="work_on_type_adverb" value="true"/>
<connect from_op="Open WordNet Dictionary" from_port="dictionary" to_op="Find Synonyms (WordNet)" to_port="dictionary"/>
<connect from_op="Read Document" from_port="output" to_op="Find Synonyms (WordNet)" to_port="document"/>
<connect from_op="Find Synonyms (WordNet)" from_port="document" to_port="result 1"/>
</process>
</process>
