HI EVERYONE
I AM DOING SIMPLE IMPACT PROBLEM USING TWO PLATE USING CONTACT B/W BOTH PLATE IS INTERFACE (TYPE 7).I CONSIDER ONE SLAVE AT WHICH I HAVE APPLIED INITIAL VELOCITY 100 MM/sec.Termination time is .4 sec.time step is 9.73e-7 sec (element size is 5 mm for steel mat).plate 1 have applied initial velocity and plate 2 size edge is fixed by spc. but i am getting
this type of error.which is in below.
** ERROR IN INPUT FORMAT
ERROR id : 266
INPUT VERSION 2018 IS NOT SUPPORTED
.. BLOCK FREE FORMAT
regards
NOOR ALAM
