<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.000" expanded="true" height="68" name="Golf" width="90" x="45" y="187"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="generate_id" compatibility="7.0.000" expanded="true" height="82" name="Generate ID" width="90" x="179" y="238"> <parameter key="create_nominal_ids" value="true"/> <description align="center" color="transparent" colored="false" width="126">Using nominal IDs just to demo.</description> </operator> <operator activated="true" class="retrieve" compatibility="7.0.000" expanded="true" height="68" name="Retrieve Golf-Testset" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Golf-Testset"/> </operator> <operator activated="true" class="subprocess" compatibility="7.0.000" expanded="true" height="82" name="Get only 1 record." width="90" x="179" y="34"> <process expanded="true"> <operator activated="true" class="sample" compatibility="7.0.000" expanded="true" height="82" name="Sample" width="90" x="45" y="34"> <parameter key="sample_size" value="1"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> </operator> <operator activated="true" class="select_attributes" compatibility="7.0.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Play"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="generate_id" compatibility="7.0.000" expanded="true" height="82" name="Generate ID (2)" width="90" x="313" y="34"/> <connect from_port="in 1" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="cross_distances" compatibility="7.0.000" expanded="true" height="103" name="Cross Distances" width="90" x="313" y="85"> <parameter key="only_top_k" value="true"/> <parameter key="k" value="3"/> </operator> <operator activated="true" class="select_attributes" compatibility="7.0.000" expanded="true" height="82" name="Select only label" width="90" x="447" y="238"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="id|Play"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="join" compatibility="7.0.000" expanded="true" height="82" name="Join to Request" width="90" x="447" y="34"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="request" value="id"/> </list> <description align="center" color="transparent" colored="false" width="126">This join is just to get the original data back rather than just the ID.</description> </operator> <operator activated="true" class="join" compatibility="7.0.000" expanded="true" height="82" name="Join to Reference" width="90" x="581" y="187"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="document" value="id"/> </list> <description align="center" color="transparent" colored="false" width="126">When the result is joined with the original Reference dataset then the label is used.</description> </operator> <connect from_op="Golf" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Cross Distances" to_port="reference set"/> <connect from_op="Retrieve Golf-Testset" from_port="output" to_op="Get only 1 record." to_port="in 1"/> <connect from_op="Get only 1 record." from_port="out 1" to_op="Cross Distances" to_port="request set"/> <connect from_op="Cross Distances" from_port="result set" to_op="Join to Request" to_port="left"/> <connect from_op="Cross Distances" from_port="request set" to_op="Join to Request" to_port="right"/> <connect from_op="Cross Distances" from_port="reference set" to_op="Select only label" to_port="example set input"/> <connect from_op="Select only label" from_port="example set output" to_op="Join to Reference" to_port="right"/> <connect from_op="Join to Request" from_port="join" to_op="Join to Reference" to_port="left"/> <connect from_op="Join to Reference" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
