<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Sonar" width="90" x="112" y="165"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.3.015" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="514" y="210"> <list key="parameters"> <parameter key="Neural Net.learning_rate" value="[0.1;1.0;10;linear]"/> </list> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="neural_net" compatibility="5.3.015" expanded="true" height="76" name="Neural Net" width="90" x="112" y="75"> <list key="hidden_layers"/> <parameter key="learning_rate" value="1.0"/> <parameter key="shuffle" value="false"/> <parameter key="normalize" value="false"/> <parameter key="use_local_random_seed" value="true"/> </operator> <connect from_port="training" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="179" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="313" y="120"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.3.015" expanded="true" height="76" name="Log" width="90" x="380" y="165"> <list key="log"> <parameter key="LearningRate" value="operator.Neural Net.parameter.learning_rate"/> <parameter key="Accuracy" value="operator.Performance.value.accuracy"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="false" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation (2)" width="90" x="380" y="30"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="neural_net" compatibility="5.3.015" expanded="true" height="76" name="Neural Net (2)" width="90" x="221" y="30"> <list key="hidden_layers"/> <parameter key="learning_rate" value="0.1"/> <parameter key="shuffle" value="false"/> <parameter key="normalize" value="false"/> <parameter key="use_local_random_seed" value="true"/> </operator> <connect from_port="training" to_op="Neural Net (2)" to_port="training set"/> <connect from_op="Neural Net (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance (2)" width="90" x="336" y="30"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Sonar" width="90" x="112" y="165"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="false" class="optimize_parameters_grid" compatibility="5.3.015" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="514" y="210"> <list key="parameters"> <parameter key="Neural Net.learning_rate" value="[0.1;1.0;10;linear]"/> </list> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="neural_net" compatibility="5.3.015" expanded="true" height="76" name="Neural Net" width="90" x="112" y="75"> <list key="hidden_layers"/> <parameter key="learning_rate" value="1.0"/> <parameter key="shuffle" value="false"/> <parameter key="normalize" value="false"/> <parameter key="use_local_random_seed" value="true"/> </operator> <connect from_port="training" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="179" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="313" y="120"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.3.015" expanded="true" height="76" name="Log" width="90" x="380" y="165"> <list key="log"> <parameter key="LearningRate" value="operator.Neural Net.parameter.learning_rate"/> <parameter key="Accuracy" value="operator.Performance.value.accuracy"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation (2)" width="90" x="380" y="30"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="neural_net" compatibility="5.3.015" expanded="true" height="76" name="Neural Net (2)" width="90" x="221" y="30"> <list key="hidden_layers"/> <parameter key="learning_rate" value="0.1"/> <parameter key="shuffle" value="false"/> <parameter key="normalize" value="false"/> <parameter key="use_local_random_seed" value="true"/> </operator> <connect from_port="training" to_op="Neural Net (2)" to_port="training set"/> <connect from_op="Neural Net (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance (2)" width="90" x="336" y="30"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Validation (2)" to_port="training"/> <connect from_op="Validation (2)" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
I thought these two numbers should be exactly the same. But they are not and they're off quite a lot in my point of view. I don't know if the parameter optimization process is reliable or not.
