MOVED: Problems with Rapidminer v6.0
Nils_Woehler
This topic has been moved to
Problems and Support
[iurl]
http://rapid-i.com/rapidforum/index.php?topic=7417.0[/iurl]
Marco_Boeck
Unfortunately there has been a slight mishap which caused your original post to vanish, we are sorry about that.
I will answer your questions here:
do I understand the issue correctly that a process with the "Read CSV" operator you used in RapidMiner 5.3.013 worked, but fails to work in RM Studio 6? If so, can you please paste the XML of the process? To do so, just click into the process and press Strg+C to copy the XML representation of it. Even better would be if you could also provide a sample of the data which the operator fails to read, e.g. the first 10 rows or so.
Regarding your second issue, operators should stay compatible when new versions are released, so you can continue using an operator from a process you created in RapidMiner 5. However the same cannot always be true the other way round - a process created in RM Studio 6 may not run on RapidMiner 5. This is evident because they may use new stuff which simply didn't exist before.
Marco
