<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Golf" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation" width="90" x="179" y="75"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="6.5.002" expanded="true" height="76" name="Naive Bayes" width="90" x="112" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="45" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_attributes" compatibility="6.5.002" expanded="true" height="94" name="Loop Attributes" width="90" x="380" y="210"> <parameter key="attributes" value="Humidity|Temperature|"/> <parameter key="value_type" value="numeric"/> <parameter key="include_special_attributes" value="true"/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_attribute}"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation (2)" width="90" x="380" y="30"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="6.5.002" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="112" y="30"/> <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance (2)" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Validation (2)" to_port="training"/> <connect from_op="Validation (2)" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Golf" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="training" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <connect from_op="Loop Attributes" from_port="result 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="30"> <parameter key="repository_entry" value="Golf"/> </operator> <operator activated="true" class="subprocess" compatibility="6.5.002" expanded="true" height="76" name="AllVariables" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation" width="90" x="45" y="75"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="6.5.002" expanded="true" height="76" name="Naive Bayes" width="90" x="112" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="45" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="performance_to_data" compatibility="6.5.002" expanded="true" height="76" name="Performance to Data" width="90" x="179" y="210"/> <operator activated="true" class="generate_empty_attribute" compatibility="6.5.002" expanded="true" height="76" name="Generate Empty Attribute" width="90" x="313" y="210"> <parameter key="name" value="nombre"/> <parameter key="value_type" value="text"/> </operator> <operator activated="true" class="set_data" compatibility="6.5.002" expanded="true" height="76" name="Set Data" width="90" x="447" y="210"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="nombre"/> <parameter key="value" value="All Variables"/> <list key="additional_values"/> </operator> <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember" width="90" x="514" y="120"> <parameter key="name" value="performances"/> </operator> <connect from_port="in 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="training" to_port="out 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Performance to Data" to_port="performance vector"/> <connect from_op="Performance to Data" from_port="example set" to_op="Generate Empty Attribute" to_port="example set input"/> <connect from_op="Generate Empty Attribute" from_port="example set output" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Remember" to_port="store"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_attributes" compatibility="6.5.002" expanded="true" height="76" name="Loop Attributes" width="90" x="313" y="30"> <parameter key="attributes" value="Humidity|Temperature|"/> <parameter key="value_type" value="numeric"/> <parameter key="include_special_attributes" value="true"/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_attribute}"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall" width="90" x="313" y="30"> <parameter key="name" value="performances"/> </operator> <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation (2)" width="90" x="179" y="30"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="6.5.002" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="112" y="30"/> <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance (2)" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="performance_to_data" compatibility="6.5.002" expanded="true" height="76" name="Performance to Data (2)" width="90" x="45" y="165"/> <operator activated="true" class="generate_empty_attribute" compatibility="6.5.002" expanded="true" height="76" name="Generate Empty Attribute (2)" width="90" x="179" y="165"> <parameter key="name" value="nombre"/> <parameter key="value_type" value="text"/> </operator> <operator activated="true" class="set_data" compatibility="6.5.002" expanded="true" height="76" name="Set Data (2)" width="90" x="313" y="165"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="nombre"/> <parameter key="value" value="%{loop_attribute}"/> <list key="additional_values"/> </operator> <operator activated="true" class="union" compatibility="6.5.002" expanded="true" height="76" name="Union" width="90" x="447" y="120"/> <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember (2)" width="90" x="581" y="120"> <parameter key="name" value="performances"/> </operator> <connect from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Validation (2)" to_port="training"/> <connect from_op="Recall" from_port="result" to_op="Union" to_port="example set 1"/> <connect from_op="Validation (2)" from_port="averagable 1" to_op="Performance to Data (2)" to_port="performance vector"/> <connect from_op="Performance to Data (2)" from_port="example set" to_op="Generate Empty Attribute (2)" to_port="example set input"/> <connect from_op="Generate Empty Attribute (2)" from_port="example set output" to_op="Set Data (2)" to_port="example set input"/> <connect from_op="Set Data (2)" from_port="example set output" to_op="Union" to_port="example set 2"/> <connect from_op="Union" from_port="union" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall (2)" width="90" x="447" y="30"> <parameter key="name" value="performances"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="AllVariables" to_port="in 1"/> <connect from_op="AllVariables" from_port="out 1" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Recall (2)" from_port="result" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
