<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_sales_data" compatibility="6.0.000" expanded="true" height="60" name="Generate Sales Data" width="90" x="45" y="30"/> <operator activated="true" class="filter_examples" compatibility="6.0.000" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="30"> <list key="filters_list"> <parameter key="filters_entry_key" value="date.lt.01/01/06"/> <parameter key="filters_entry_key" value="date.gt.12/31/07"/> </list> <parameter key="filters_logic_and" value="false"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
