<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <operator activated="true" class="log" compatibility="7.0.000" expanded="true" height="82" name="Log" width="90" x="581" y="85"> <parameter key="filename" value="D:\log_values.txt"/> <list key="log"> <parameter key="Count" value="operator.SVM.value.applycount"/> <parameter key=" Testing Error" value="operator.Performance.value.performance"/> <parameter key="Training Error" value="operator.Performance (2).value.performance"/> <parameter key="SVM C" value="operator.SVM.parameter.C"/> <parameter key="SVM gamma" value="operator.SVM.parameter.gamma"/> </list> <parameter key="sorting_type" value="none"/> <parameter key="sorting_k" value="100"/> <parameter key="persistent" value="false"/> </operator></process>
