Connecting output of Loop Value block to Join Input
Karan_Kansal
I am trying connect the output from the loop values block to a Join but I face the following error:
Some input of type com.rapidminer.example.ExampleSet in not provided.
I think the error occurs because I am trying to connect IOObject output to the Join Input. I have tried using the Append and Flatten Collection blocks but to no avail.
Any ideas on solving this issue .
Help is greatly appreciated
Thanks
Loops + Branches
Karan_Kansal
Below is the XML code:
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve HCP Data" width="90" x="45" y="75">
<parameter key="repository_entry" value="//CCM Suggestion Engine/HCP Data"/>
<operator activated="true" class="rename_by_replacing" compatibility="6.4.000" expanded="true" height="76" name="Rename by Replacing" width="90" x="112" y="165">
<parameter key="replace_what" value=" "/>
<parameter key="replace_by" value="_"/>
<operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Threshold Data" width="90" x="45" y="300">
<parameter key="repository_entry" value="//CCM Suggestion Engine/Threshold Data"/>
<operator activated="true" class="rename_by_replacing" compatibility="6.4.000" expanded="true" height="76" name="Rename by Replacing (2)" width="90" x="179" y="345">
<operator activated="true" class="join" compatibility="6.4.000" expanded="true" height="76" name="Join" width="90" x="246" y="210">
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="Metric_ID" value="Metric_ID"/>
</list>
<operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values" width="90" x="581" y="165">
<parameter key="attribute" value="HCP_ID"/>
<operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples" width="90" x="313" y="120">
<list key="filters_list">
<parameter key="filters_entry_key" value="HCP_ID.equals.%{loop_value}"/>
</list>
<operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values (2)" width="90" x="581" y="210">
<parameter key="attribute" value="Metric_ID"/>
<parameter key="iteration_macro" value="Primary_metric"/>
<operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (2)" width="90" x="45" y="30">
<parameter key="parameter_expression" value="Metric_Value>=Lower_Threshold&&Metric_Value<=Upper_Threshold&&Metric_ID==macro("Primary_metric")"/>
<parameter key="condition_class" value="expression"/>
<parameter key="filters_entry_key" value="Metric_Value.ge.Lower_Threshold"/>
<parameter key="filters_entry_key" value="Metric_Value.le.Upper_Threshold"/>
</list>
<operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Metric Data" width="90" x="45" y="255">
<parameter key="repository_entry" value="Metric Data"/>
<operator activated="true" class="rename_by_replacing" compatibility="6.4.000" expanded="true" height="76" name="Rename by Replacing (3)" width="90" x="179" y="255">
<operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (4)" width="90" x="313" y="165">
<parameter key="parameter_expression" value="Primary_Metric_ID==macro("Primary_metric")"/>
<list key="filters_list"/>
<operator activated="true" class="join" compatibility="6.4.000" expanded="true" height="76" name="Join (2)" width="90" x="380" y="30">
<parameter key="Metric_ID" value="Primary_Metric_ID"/>
</list>
<operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="447" y="165"/>
<operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values (3)" width="90" x="581" y="210">
<operator activated="true" class="replace_missing_values" compatibility="6.4.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="380" y="390">
<list key="columns">
<parameter key="Diagnostic_Metric_ID" value="zero"/>
</list>
<operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (3)" width="90" x="514" y="390">
<parameter key="parameter_expression" value="Diagnostic_Metric_ID==0"/>
<connect from_port="example set" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Filter Examples (3)" to_port="example set input"/>
<connect from_op="Filter Examples (3)" from_port="example set output" to_port="out 1"/>
</process>
<operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="715" y="255"/>
<operator activated="true" class="join" compatibility="6.4.000" expanded="true" height="76" name="Join (3)" width="90" x="782" y="120">
<parameter key="Diagnostic_Metric_ID" value="Metric_ID"/>
<parameter key="HCP_ID" value="HCP_ID"/>
</list>
<connect from_port="example set" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Join (2)" to_port="left"/>
<connect from_op="Retrieve Metric Data" from_port="output" to_op="Rename by Replacing (3)" to_port="example set input"/>
<connect from_op="Rename by Replacing (3)" from_port="example set output" to_op="Filter Examples (4)" to_port="example set input"/>
<connect from_op="Filter Examples (4)" from_port="example set output" to_op="Join (2)" to_port="right"/>
<connect from_op="Join (2)" from_port="join" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Join (3)" to_port="left"/>
<connect from_op="Multiply" from_port="output 2" to_op="Loop Values (3)" to_port="example set"/>
<connect from_op="Loop Values (3)" from_port="out 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_op="Join (3)" to_port="right"/>
<connect from_op="Join (3)" from_port="join" to_port="out 1"/>
</process>
<connect from_port="example set" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Loop Values (2)" to_port="example set"/>
<connect from_op="Loop Values (2)" from_port="out 1" to_port="out 1"/>
<description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="607" y="208">Type your comment</description>
</process>
<operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append (2)" width="90" x="715" y="165"/>
<connect from_op="Retrieve HCP Data" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Retrieve Threshold Data" from_port="output" to_op="Rename by Replacing (2)" to_port="example set input"/>
<connect from_op="Rename by Replacing (2)" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Join" from_port="join" to_op="Loop Values" to_port="example set"/>
<connect from_op="Loop Values" from_port="out 1" to_op="Append (2)" to_port="example set 1"/>
<connect from_op="Append (2)" from_port="merged set" to_port="result 1"/>
</process>
</process>
MartinLiebig
i think there is a append missing after Loop Values (2).
~Martin
Karan_Kansal
Hi Martin,
I tried using an Append after loop Values (2) but I am still facing the same issue. The XML code is given below after using Append:
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</list>
<operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values (2)" width="90" x="514" y="210">
</list>
</list>
</list>
</process>
</list>
</process>
<operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append (3)" width="90" x="648" y="210"/>
<connect from_op="Loop Values (2)" from_port="out 1" to_op="Append (3)" to_port="example set 1"/>
<connect from_op="Append (3)" from_port="merged set" to_port="out 1"/>
</process>
</process>
</process>
sgenzer
Martin - when I put this XML into RM 7.0, I do NOT get a process. Do you?
Marco_Boeck
not Martin, but answering anyway: Works for me. What does your log say when you do it?
Marco
sgenzer
I just paste the XML and then I see nothing in the process window. From what I can tell, RM 7.0 tries to validate the process and then deletes it. If I validate the process manually, the same result happens. Does RM 7.0 not accept XML from prior versions?
Scott
Marco_Boeck
I have been using our development version so far and also just switched to the 7.0 release version. In both I can paste the process no problem. Does the "Log" panel show something when you paste your process?
Marco
