<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="7.0.000" expanded="true" height="82" name="Subprocess" width="90" x="45" y="34"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="select_attributes" compatibility="7.0.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="map" compatibility="7.0.000" expanded="true" height="82" name="Map" width="90" x="313" y="34"> <parameter key="include_special_attributes" value="true"/> <list key="value_mappings"> <parameter key="Iris-setosa" value="Bill"/> <parameter key="Iris-virginica" value="Mary"/> <parameter key="Iris-versicolor" value="Bob"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="7.0.000" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="34"> <list key="function_descriptions"> <parameter key="Group" value="round(rand()*100)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="7.0.000" expanded="true" height="82" name="Set Role" width="90" x="581" y="34"> <parameter key="attribute_name" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="rename" compatibility="7.0.000" expanded="true" height="82" name="Rename" width="90" x="715" y="34"> <parameter key="old_name" value="label"/> <parameter key="new_name" value="User"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Map" to_port="example set input"/> <connect from_op="Map" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Get a fitting Data Set</description> </operator> <operator activated="true" class="generate_id" compatibility="7.0.000" expanded="true" height="82" name="Generate ID" width="90" x="179" y="34"/> <operator activated="true" class="pivot" compatibility="7.0.000" expanded="true" height="82" name="Pivot" width="90" x="313" y="34"> <parameter key="group_attribute" value="User"/> <parameter key="index_attribute" value="id"/> <parameter key="consider_weights" value="false"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="7.0.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="447" y="34"> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="set_role" compatibility="7.0.000" expanded="true" height="82" name="Set Role (2)" width="90" x="581" y="34"> <parameter key="attribute_name" value="User"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="loop_attributes" compatibility="7.0.000" expanded="true" height="82" name="Loop Attributes" width="90" x="849" y="34"> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="7.0.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="112" y="34"> <list key="function_descriptions"> <parameter key="%{loop_attribute}" value="if(#{loop_attribute}==0,"false","true")"/> </list> </operator> <connect from_port="example set" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Subprocess" from_port="out 1" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="7.0.000" expanded="true" height="82" name="Subprocess" width="90" x="45" y="34"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="7.0.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="34"> <parameter key="text" value="User,Group bill,2 bill,1 bill,3 mary,1 mary,2 ed,3 "/> </operator> <operator activated="true" class="text:write_document" compatibility="7.0.000" expanded="true" height="82" name="Write Document" width="90" x="179" y="85"/> <operator activated="true" class="read_csv" compatibility="7.0.000" expanded="true" height="68" name="Read CSV" width="90" x="380" y="85"> <parameter key="column_separators" value=","/> <parameter key="use_quotes" value="false"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="User.true.nominal.attribute"/> <parameter key="1" value="Group.true.polynominal.attribute"/> </list> </operator> <connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="file" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Get a fitting Data Set</description> </operator> <operator activated="true" class="generate_attributes" compatibility="7.0.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34"> <list key="function_descriptions"> <parameter key="member_of_group" value="1"/> </list> <description align="center" color="transparent" colored="false" width="126">This adds a value attribute to the dataset.</description> </operator> <operator activated="true" class="pivot" compatibility="7.0.000" expanded="true" height="82" name="Pivot" width="90" x="313" y="34"> <parameter key="group_attribute" value="User"/> <parameter key="index_attribute" value="Group"/> <parameter key="consider_weights" value="false"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="7.0.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="447" y="34"/> <operator activated="true" class="replace_missing_values" compatibility="7.0.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="value_type" value="binominal"/> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="false"/> </operator> <operator activated="true" class="order_attributes" compatibility="7.0.000" expanded="true" height="82" name="Reorder Attributes" width="90" x="715" y="34"> <parameter key="attribute_ordering" value="User"/> <description align="center" color="transparent" colored="false" width="126">This is just to move the User column back to the front &amp; ensure every other group is also ordered alphabetically.</description> </operator> <operator activated="true" class="set_role" compatibility="7.0.000" expanded="true" height="82" name="Set Role" width="90" x="581" y="238"> <parameter key="attribute_name" value="User"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="fp_growth" compatibility="7.0.000" expanded="true" height="82" name="FP-Growth" width="90" x="849" y="238"/> <operator activated="true" class="create_association_rules" compatibility="7.0.000" expanded="true" height="82" name="Create Association Rules" width="90" x="849" y="85"/> <connect from_op="Subprocess" from_port="out 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="FP-Growth" to_port="example set"/> <connect from_op="FP-Growth" from_port="example set" to_port="result 2"/> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
