"Please help me to use web mining and clawling"
ezoulias
Dear friends,
I have a problem with web mining and clawling.
Although I see that Web Mining Extension is downloaded and installed. I can not find the Web Mining folder under the Operators sections to select the Crawl Web or other operators.
Best regards,
manols
Web Mining
MariusHelf
how did you install the Web extension? How did you check that it has been installed?
Best regards,
Marius
ezoulias
I installed via Help -> Updates and Extensions -> Updates.
I checked that it is installed via Help -> Manage Extensions.
Thank you in advance
Manolis
Marco_Boeck
can you post the contents of the rapidminerm-studio.log (or rm.log for RM 5)? You can find it inside the USER folder on your OS in the .RapidMiner (.RapidMiner5) subfolder.
Marco
ezoulias
I found two files rm.log and rm.log.1.
Each of them exceeds the 20000 characters.
I sent you both into different posts
rm.log part 1/2
Jan 12, 2014 9:28:38 AM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Jan 12, 2014 9:28:40 AM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: QuantX-1 Extension
INFO: Register plugin: Reporting
INFO: Register plugin: Anomaly Detection
INFO: Register plugin: Text Processing
INFO: Register plugin: Parallel Processing
INFO: Register plugin: LifeStyle Marketing
INFO: Register plugin: R Extension
INFO: Register plugin: Feature-Selection-Extension
INFO: Register plugin: PRules
INFO: Register plugin: semweb
INFO: Register plugin: recommenders
INFO: Register plugin: PMML
INFO: Register plugin: WordNet
INFO: Register plugin: Tacl
INFO: Register plugin: MLWizard
INFO: Register plugin: Web Mining
INFO: Register plugin: Series
INFO: Register plugin: SOM
INFO: Register plugin: Intelligent Discovery Assistant
INFO: Register plugin: Weka
INFO: Register plugin: Ontological Extension for RM
INFO: Register plugin: Extension Development
INFO: Register plugin: Community
INFO: Register plugin: WhiBo
INFO: Register plugin: ImageMiner
Jan 12, 2014 9:28:41 AM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
WARNING: Error initializing plugin: java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/ErrorsReporting, locale en
at java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
at java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.util.ResourceBundle.getBundle(Unknown Source)
at com.rapidminer.tools.plugin.Plugin.registerDescriptions(Plugin.java:500)
at com.rapidminer.tools.plugin.Plugin.registerAllPluginDescriptions(Plugin.java:738)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:982)
at com.rapidminer.RapidMiner.init(RapidMiner.java:521)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:240)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:559)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:540)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.rapid_i.Launcher.main(Launcher.java:367)
WARNING: Error initializing plugin: java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/ErrorsR, locale en
Jan 12, 2014 9:28:42 AM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
WARNING: Error initializing plugin: java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/ErrorsWeb, locale en
Jan 12, 2014 9:28:43 AM com.rapidminer.tools.ClassColorMap parseKey
SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.gdt_operators.whibo_gdt_evolutionary_search
SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.validation.5x2_xvalidation_ftest
SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.gdt_operators.gdt_algorithm
SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.validation.xvalidation_with_log
Jan 12, 2014 9:28:43 AM com.rapidminer.tools.plugin.Plugin callInitMethod
WARNING: Plugin initializer com.rapidminer.ParallelPluginInit.initPlugin of Plugin Parallel Processing caused an error: null
java.lang.reflect.InvocationTargetException
at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:896)
at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:869)
at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:849)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:984)
Caused by: java.lang.NoClassDefFoundError: com/rapidminer/operator/executor/ParallelUnitExecutorFactory$1
at com.rapidminer.operator.executor.ParallelUnitExecutorFactory.install(ParallelUnitExecutorFactory.java:50)
at com.rapidminer.ParallelPluginInit.initPlugin(ParallelPluginInit.java:40)
... 17 more
Caused by: java.lang.ClassNotFoundException: com.rapidminer.operator.executor.ParallelUnitExecutorFactory$1
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at com.rapidminer.tools.plugin.PluginClassLoader.loadClass(PluginClassLoader.java:102)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 19 more
Jan 12, 2014 9:28:45 AM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
Jan 12, 2014 9:28:50 AM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Jan 12, 2014 9:28:51 AM com.rapidminer.tools.OperatorService init
INFO: Loading additional operators specified by rapidminer.operators.additional (${RAPIDMINER_OPERATORS_ADDITIONAL})
SEVERE: Cannot find operator description file ${RAPIDMINER_OPERATORS_ADDITIONAL}.
Jan 12, 2014 9:28:52 AM com.rapidminer.tools.math.similarity.DistanceMeasureHelper updateMeasure
WARNING: While updating distance measure: com.rapidminer.parameter.UndefinedParameterError: A value for the parameter 'measure_types' must be specified! Expected integer but found 'null'.
Jan 12, 2014 9:28:57 AM com.rapidminer.tools.plugin.Plugin registerOperators
INFO: No operator descriptor specified for plugin Community. Trying plugin initializtation class com.rapidminer.community.CommunityPluginInit.
WARNING: No operator descriptor defined for: Community
Jan 12, 2014 9:28:57 AM com.rapidminer.operator.ExecutionUnit <init>
WARNING: Process name does not follow naming conventions: Evolutionary search on WhiBo (in WhiBo GDT Evolutionary Search)
Jan 12, 2014 9:28:58 AM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 936; number of registered operator descriptions: 1,062; number of replacements: 577
Jan 12, 2014 9:28:59 AM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Jan 12, 2014 9:28:59 AM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
Jan 12, 2014 9:29:09 AM com.rapidminer.gui.ApplicationPerspectives loadAll
CONFIG: Loading perspectives.
Jan 12, 2014 9:29:09 AM com.rapidminer.elico.ida.IDAPluginInit initGui
INFO: Initializing IDA GUI
Jan 12, 2014 9:29:09 AM com.rapidminer.elico.ida.gui.dockable.WelcomeStep whitify
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@c42548,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import Excel Sheet...,defaultCapable=true]
INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@c42548,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import CSV File...,defaultCapable=true]
INFO: Whitify com.rapidminer.gui.tools.ExtendedHTMLJEditorPane[,0,0,0x0,invalid,layout=javax.swing.plaf.basic.BasicTextUI$UpdateHandler,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.basic.BasicBorders$MarginBorder@a62825,flags=296,maximumSize=,minimumSize=,preferredSize=,caretColor=javax.swing.plaf.ColorUIResource[r=0,g=25,b=100],disabledTextColor=javax.swing.plaf.ColorUIResource[r=180,g=180,b=180],editable=false,margin=javax.swing.plaf.InsetsUIResource[top=4,left=6,bottom=4,right=6],selectedTextColor=javax.swing.plaf.ColorUIResource[r=255,g=255,b=255],selectionColor=javax.swing.plaf.ColorUIResource[r=150,g=150,b=170],kit=com.rapidminer.gui.tools.ExtendedHTMLEditorKit@16baee0,typeHandlers=]
INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=8388608,maximumSize=,minimumSize=java.awt.Dimension[width=400,height=200],preferredSize=java.awt.Dimension[width=400,height=200],defaultIcon=,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=Drop data here,verticalAlignment=CENTER,verticalTextPosition=CENTER]
INFO: Whitify javax.swing.Box[,0,0,0x0,invalid,layout=javax.swing.BoxLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@ccb3a6,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=java.awt.Dimension[width=400,height=200],preferredSize=java.awt.Dimension[width=400,height=200],defaultIcon=,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=Drop data here,verticalAlignment=CENTER,verticalTextPosition=CENTER]
INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=8,height=32767],minimumSize=java.awt.Dimension[width=8,height=0],preferredSize=java.awt.Dimension[width=8,height=0]]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@1268e11,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=32767,height=0],minimumSize=java.awt.Dimension[width=0,height=0],preferredSize=java.awt.Dimension[width=0,height=0]]
ezoulias
rm.log part 2/2
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=java.awt.Dimension[width=200,height=200],minimumSize=java.awt.Dimension[width=200,height=200],preferredSize=java.awt.Dimension[width=200,height=200],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=5,height=32767],minimumSize=java.awt.Dimension[width=5,height=0],preferredSize=java.awt.Dimension[width=5,height=0]]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.EmptyBorder@1ae7355,flags=9,maximumSize=java.awt.Dimension[width=620,height=1000],minimumSize=java.awt.Dimension[width=620,height=80],preferredSize=java.awt.Dimension[width=620,height=210]]
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=,minimumSize=,preferredSize=,columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,hidden,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/16/error.png,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=,verticalAlignment=CENTER,verticalTextPosition=CENTER]
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=java.awt.Dimension[width=350,height=250],minimumSize=java.awt.Dimension[width=350,height=100],preferredSize=java.awt.Dimension[width=350,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=10,height=32767],minimumSize=java.awt.Dimension[width=10,height=0],preferredSize=java.awt.Dimension[width=10,height=0]]
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=java.awt.Dimension[width=500,height=250],minimumSize=java.awt.Dimension[width=500,height=100],preferredSize=java.awt.Dimension[width=500,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
Jan 12, 2014 9:29:10 AM com.rapidminer.elico.ida.installer.InstallerUtils readCurrentVersion
INFO: Current IDA version is 01.023
Jan 12, 2014 9:29:11 AM com.rapidminer.elico.ida.installer.IDAUpdater checkForUpdateNow
INFO: IDA is up to date.
Jan 12, 2014 9:29:11 AM com.rapidminer.io.community.MyExperimentConnection connectTo
INFO: Connecting to:
http://www.myexperiment.org/search.xml?num=100&
;query=kind%3A%28RapidMiner%29&type=workflow
Jan 12, 2014 9:29:12 AM com.rapidminer.gui.security.Wallet readCache
CONFIG: Reading secrets file.
Jan 12, 2014 9:29:13 AM com.rapid_i.deployment.update.client.UpdateManager$3 run
INFO: Checking for updates.
Jan 12, 2014 9:29:16 AM com.rapid_i.deployment.update.client.UpdateManager$3 run
INFO: No updates since 1/9/14 5:40 PM.
Jan 12, 2014 9:35:49 AM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
INFO: Running shutdown sequence.
Jan 12, 2014 9:35:49 AM com.rapidminer.gui.ApplicationPerspectives saveAll
CONFIG: Saving perspectives.
Jan 12, 2014 9:35:49 AM com.rapidminer.tools.usagestats.UsageStatistics save
CONFIG: Saving operator usage.
WARNING: Cannot save operator usage statistics: org.w3c.dom.DOMException: INVALID_CHARACTER_ERR: An invalid or illegal XML character is specified.
at com.sun.org.apache.xerces.internal.dom.CoreDocumentImpl.createElement(Unknown Source)
at com.rapidminer.tools.usagestats.OperatorUsageStatistics.getXML(OperatorUsageStatistics.java:67)
at com.rapidminer.tools.usagestats.UsageStatistics.getXML(UsageStatistics.java:283)
at com.rapidminer.tools.usagestats.UsageStatistics.save(UsageStatistics.java:296)
at com.rapidminer.gui.RapidMinerGUI$ShutdownHook.run(RapidMinerGUI.java:216)
at com.rapidminer.RapidMiner.quit(RapidMiner.java:760)
at com.rapidminer.gui.MainFrame.exit(MainFrame.java:1566)
at com.rapidminer.gui.MainFrame.windowClosing(MainFrame.java:1597)
at java.awt.AWTEventMulticaster.windowClosing(Unknown Source)
at java.awt.Window.processWindowEvent(Unknown Source)
at javax.swing.JFrame.processWindowEvent(Unknown Source)
at java.awt.Window.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
end of rm.log
ezoulias
rm.log.1 part 1/2
Οκτ 30, 2013 10:41:50 ΜΜ com.rapidminer.RapidMiner performFirstInitialization
INFO: Performing upgrade from version 5.3.008 to version 5.3.013
Oct 30, 2013 10:41:50 PM com.rapidminer.tools.I18N <clinit>
Oct 30, 2013 10:42:02 PM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Information-Extraction
Oct 30, 2013 10:42:08 PM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
at com.rapidminer.tools.plugin.Plugin.registerDescriptions(Plugin.java:501)
at com.rapidminer.tools.plugin.Plugin.registerAllPluginDescriptions(Plugin.java:739)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:983)
at com.rapidminer.RapidMiner.init(RapidMiner.java:550)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:241)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:560)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:541)
at com.rapid_i.Launcher.main(Launcher.java:346)
Oct 30, 2013 10:42:09 PM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
Oct 30, 2013 10:42:11 PM com.rapidminer.tools.plugin.Plugin callInitMethod
at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:897)
at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:870)
at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:850)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:985)
... 17 more
... 19 more
Oct 30, 2013 10:42:24 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
Oct 30, 2013 10:42:34 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
Oct 30, 2013 10:42:39 PM com.rapidminer.tools.OperatorService init
Oct 30, 2013 10:42:39 PM com.rapidminer.tools.math.similarity.DistanceMeasureHelper updateMeasure
Oct 30, 2013 10:42:41 PM com.rapidminer.tools.OperatorService parseOperators
WARNING: Cannot create operator description: rmx_information_extraction : binary_kernel_naiveBayes_operator
java.lang.ClassNotFoundException: com.rapidminer.operator.learner.bayes.BinaryTreeKernelNaiveBayes
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.rapidminer.operator.OperatorDescription.<init>(OperatorDescription.java:93)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:300)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:293)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:269)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:231)
at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:484)
at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:808)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:181)
at com.rapidminer.RapidMiner.init(RapidMiner.java:559)
Oct 30, 2013 10:42:53 PM com.rapidminer.operator.LifeStyle_Marketing.LifeStyle_Targeting WriteLog
SEVERE: Error com.rapidminer.operator.ports.metadata.MetaData cannot be cast to com.rapidminer.operator.ports.metadata.ExampleSetMetaData .
Oct 30, 2013 10:42:54 PM com.rapidminer.tools.plugin.Plugin registerOperators
Oct 30, 2013 10:42:56 PM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 952; number of registered operator descriptions: 1,078; number of replacements: 577
Oct 30, 2013 10:42:57 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
Oct 30, 2013 10:42:57 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
Oct 30, 2013 10:43:43 PM com.rapidminer.gui.ApplicationPerspectives loadAll
Oct 30, 2013 10:43:44 PM com.rapidminer.elico.ida.IDAPluginInit initGui
Oct 30, 2013 10:43:44 PM com.rapidminer.elico.ida.gui.dockable.WelcomeStep whitify
INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@61f835,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import Excel Sheet...,defaultCapable=true]
INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@61f835,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import CSV File...,defaultCapable=true]
INFO: Whitify com.rapidminer.gui.tools.ExtendedHTMLJEditorPane[,0,0,0x0,invalid,layout=javax.swing.plaf.basic.BasicTextUI$UpdateHandler,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.basic.BasicBorders$MarginBorder@224b7e,flags=296,maximumSize=,minimumSize=,preferredSize=,caretColor=javax.swing.plaf.ColorUIResource[r=0,g=25,b=100],disabledTextColor=javax.swing.plaf.ColorUIResource[r=180,g=180,b=180],editable=false,margin=javax.swing.plaf.InsetsUIResource[top=4,left=6,bottom=4,right=6],selectedTextColor=javax.swing.plaf.ColorUIResource[r=255,g=255,b=255],selectionColor=javax.swing.plaf.ColorUIResource[r=150,g=150,b=170],kit=com.rapidminer.gui.tools.ExtendedHTMLEditorKit@1ee64e6,typeHandlers=]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@4a8179,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@17a6052,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
ezoulias
rm.log.1 part 2/2
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=java.awt.Dimension[width=200,height=200],minimumSize=java.awt.Dimension[width=200,height=200],preferredSize=java.awt.Dimension[width=200,height=200],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.EmptyBorder@249fc0,flags=9,maximumSize=java.awt.Dimension[width=620,height=1000],minimumSize=java.awt.Dimension[width=620,height=80],preferredSize=java.awt.Dimension[width=620,height=210]]
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=,minimumSize=,preferredSize=,columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=java.awt.Dimension[width=350,height=250],minimumSize=java.awt.Dimension[width=350,height=100],preferredSize=java.awt.Dimension[width=350,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=java.awt.Dimension[width=500,height=250],minimumSize=java.awt.Dimension[width=500,height=100],preferredSize=java.awt.Dimension[width=500,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
Oct 30, 2013 10:43:45 PM com.rapidminer.elico.ida.installer.InstallerUtils readCurrentVersion
Oct 30, 2013 10:43:46 PM com.rapid_i.deployment.update.client.UpdateManager checkForUpdates
CONFIG: Ignoring update check. Last update check was on 10/30/13 7:08 PM.
Oct 30, 2013 10:43:48 PM com.rapidminer.elico.ida.installer.IDAUpdater checkForUpdateNow
Oct 30, 2013 10:43:48 PM com.rapidminer.io.community.MyExperimentConnection connectTo
Oct 30, 2013 10:43:54 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
Oct 30, 2013 10:43:54 PM com.rapidminer.gui.ApplicationPerspectives saveAll
Oct 30, 2013 10:43:55 PM com.rapidminer.tools.usagestats.UsageStatistics save
at com.rapidminer.gui.RapidMinerGUI$ShutdownHook.run(RapidMinerGUI.java:217)
at com.rapidminer.RapidMiner.quit(RapidMiner.java:804)
at java.awt.EvanceentDispatchThread.pumpEventsForFilter(Unknown Source)
end of rm.log.1
thank you in advance
manolis
Marco_Boeck
there seems to be a problem loading some extensions. I do not know what causes this from here, so could you please try the following:
Move (not copy) all .jar files from USER/.RapidMiner5/managed folder somewhere else. All .jars in said folder are loaded as plugins, so moving them somewhere else will remove those extensions from RapidMiner for the time being. Afterwards please look into your RM installation folder, specifically in the lib/plugins subfolder. Are there also extensions in there? If so, move them to a backup place as well. Now start RapidMiner, it should load no plugins at all. Now go to the Update/Marketplace dialog again, and select only the web mining plugin. It should tell you that there is a depdency (text mining). After you have downloaded them both, restart RapidMiner as requested. Can you now see the "Text Processing" and "Web Mining" operator categories?
If so, you can now re-add the other extensions you need. Check after each one that the others are still functional, in case there is a conflict. If there is or any other problem arises, feel free to ask.
Marco
ezoulias
It seems that my problem solved.
I understand now the way of debug.
thank you very much for your help
