<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.1.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.1.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.1.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
