<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="6.5.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="34"> <parameter key="text" value="This is one text"/> </operator> <operator activated="true" class="text:process_documents" compatibility="6.5.000" expanded="true" height="103" name="Process Documents" width="90" x="246" y="34"> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="6.5.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:create_document" compatibility="6.5.000" expanded="true" height="68" name="Create Document (2)" width="90" x="45" y="187"> <parameter key="text" value="And this is the other text"/> </operator> <operator activated="true" class="text:process_documents" compatibility="6.5.000" expanded="true" height="103" name="Process Documents (2)" width="90" x="380" y="136"> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="6.5.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="112" y="34"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_id" compatibility="7.0.000" expanded="true" height="82" name="Generate ID" width="90" x="514" y="136"> <parameter key="offset" value="500"/> </operator> <operator activated="true" class="generate_id" compatibility="7.0.000" expanded="true" height="82" name="Generate ID (2)" width="90" x="514" y="34"> <parameter key="offset" value="1"/> </operator> <operator activated="true" class="cross_distances" compatibility="7.0.000" expanded="true" height="103" name="Cross Distances" width="90" x="648" y="85"/> <operator activated="true" class="join" compatibility="7.0.000" expanded="true" height="82" name="Join" width="90" x="782" y="34"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="request" value="id"/> </list> </operator> <operator activated="true" class="join" compatibility="7.0.000" expanded="true" height="82" name="Join (2)" width="90" x="916" y="85"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="document" value="id"/> </list> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Process Documents" from_port="word list" to_op="Process Documents (2)" to_port="word list"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Process Documents (2)" from_port="example set" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Cross Distances" to_port="reference set"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Cross Distances" to_port="request set"/> <connect from_op="Cross Distances" from_port="result set" to_op="Join" to_port="left"/> <connect from_op="Cross Distances" from_port="request set" to_op="Join" to_port="right"/> <connect from_op="Cross Distances" from_port="reference set" to_op="Join (2)" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
