Use results of older blocks
Pieter
Hi all,
When using blocks a green circle indicates if they already have run. When running the whole pipeline and then changing some parameters from blocks in the middle, earlier blocks remain having a green circle and later blocks get a yellow circle. It's like it indicates that results of blocks after the block with the changed parameter are not valid anymore but the ones before are.
But when starting the pipeline again it starts from the beginning. Is there any way that it could start from the block with changed parameters and use the results from the previous results from the blocks before the block with the changed parameters?
Pieter
Does anyone has a clue?
Marco_Boeck
no. At the moment, the indicator means that the meta data at the output ports is still valid, not that the actual data is still present.
Marco
