I'm using Law 38 for a model using a foam specimen (see image1), an impactor and a anvil. I try to model the unloading of that foam block. I tried 2 methods following Altair helps:
1- I use a single unloading curve (see image2). It's working but, the calculation time is very high compared to the model without a unloading curve
2- I use the same unloading curve but I use it like a quasistatic curve using strain rate at 0 and the next curve at 0.0001 (see image3). I also put K_R parameter to 1. Calculation time is almost infinite, so not an option.
What I'm a doing wrong, or what should I do to make it work. Here's the attached model too.
Thanks!
JM
