Hello everyone I am currently trying to perform a simple logistic regression on a hotel dataset trying to predict whether customers are more likely to book a classic_roomtype or not, based on variables like amount, frequency of visits, number of nights spent e.t.c. The problem is after running the model everything works fine except that in viewing my results there is no data pane to actually view in text the accuracy of the model. and yes the accuracy box have been checked. I don't know if it's a problem of the version of rapid miner am using or there's a setting I haven't quite checked yet. Would really appreciate your help.
<process version="6.5.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="6.5.002" expanded="true" height="60" name="Read CSV" width="90" x="179" y="75">
<parameter key="csv_file" value="C:\Users\Aisha\skype\hotelData.csv"/>
<parameter key="column_separators" value=",\s*|;\s*"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="windows-1252"/>
<parameter key="0" value="freq.true.integer.attribute"/>
<parameter key="1" value="nights.true.integer.attribute"/>
<parameter key="2" value="amount.true.real.attribute"/>
<parameter key="3" value="Sex_Male.true.integer.attribute"/>
<parameter key="4" value="Room_Classic.true.binominal.label"/>
<parameter key="5" value="Purpose_Business.true.integer.attribute"/>
<parameter key="6" value="BillTo_Company.true.integer.attribute"/>
</list>
<operator activated="true" class="split_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation" width="90" x="514" y="75">
<parameter key="split_ratio" value="0.8"/>
<parameter key="sampling_type" value="stratified sampling"/>
<operator activated="true" class="logistic_regression" compatibility="6.5.002" expanded="true" height="94" name="Logistic Regression" width="90" x="45" y="30"/>
<connect from_port="training" to_op="Logistic Regression" to_port="training set"/>
<connect from_op="Logistic Regression" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance" width="90" x="246" y="30">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
</process>
</process>
In my results overview pane, the only thing that shows is the Description, Weight Table, Support Vector table, Charts, and Annotation
