<?xml version="1.0" encoding="UTF-8" standalone="no"?><process > <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="subprocess" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Subprocess" width="90" x="179" y="34"> <process expanded="true"> <operator activated="true" class="generate_id" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Generate ID" width="90" x="45" y="34"/> <operator activated="true" class="select_attributes" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="attribute_1"/> </operator> <connect from_port="in 1" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="7.0.000-SNAPSHOT" expanded="true" height="103" name="Multiply" width="90" x="346" y="34"/> <operator activated="true" class="sample" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Sample" width="90" x="514" y="34"> <parameter key="sample" value="relative"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="5"/> </operator> <operator activated="true" class="normalize" compatibility="7.0.000-SNAPSHOT" expanded="true" height="103" name="Normalize" width="90" x="648" y="34"/> <operator activated="true" class="rename" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Rename" width="90" x="782" y="34"> <parameter key="old_name" value="attribute_1"/> <parameter key="new_name" value="Normalized after sampling_Z-Transformation"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="materialize_data" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Materialize Data" width="90" x="514" y="238"/> <operator activated="true" class="normalize" compatibility="7.0.000-SNAPSHOT" expanded="true" height="103" name="Normalize (2)" width="90" x="648" y="238"/> <operator activated="true" class="sample" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Sample (2)" width="90" x="782" y="238"> <parameter key="sample" value="relative"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="5"/> </operator> <operator activated="true" class="rename" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Rename (2)" width="90" x="849" y="136"> <parameter key="old_name" value="attribute_1"/> <parameter key="new_name" value="Normalized before sampling Z-Transformation"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="join" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Join" width="90" x="916" y="34"> <list key="key_attributes"/> </operator> <operator activated="true" class="sample" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Sample (3)" width="90" x="514" y="442"> <parameter key="sample" value="relative"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="5"/> </operator> <operator activated="true" class="normalize" compatibility="7.0.000-SNAPSHOT" expanded="true" height="103" name="Normalize (4)" width="90" x="648" y="442"> <parameter key="method" value="range transformation"/> </operator> <operator activated="true" class="rename" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Rename (4)" width="90" x="782" y="442"> <parameter key="old_name" value="attribute_1"/> <parameter key="new_name" value="Normalized after sampling 0-1-Transformation"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="retrieve" compatibility="7.0.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Sonar (2)" width="90" x="112" y="646"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="subprocess" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Subprocess (2)" width="90" x="313" y="646"> <process expanded="true"> <operator activated="true" class="generate_id" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Generate ID (2)" width="90" x="45" y="34"/> <operator activated="true" class="select_attributes" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Select Attributes (2)" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="attribute_1"/> </operator> <connect from_port="in 1" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="materialize_data" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Materialize Data (2)" width="90" x="514" y="646"> <parameter key="datamanagement" value="float_array"/> </operator> <operator activated="true" class="normalize" compatibility="7.0.000-SNAPSHOT" expanded="true" height="103" name="Normalize (3)" width="90" x="648" y="646"> <parameter key="method" value="range transformation"/> </operator> <operator activated="true" class="sample" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Sample (4)" width="90" x="782" y="646"> <parameter key="sample" value="relative"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="5"/> </operator> <operator activated="true" class="rename" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Rename (3)" width="90" x="916" y="544"> <parameter key="old_name" value="attribute_1"/> <parameter key="new_name" value="Normalized before sampling 0-1 Transformation"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="join" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Join (2)" width="90" x="983" y="442"> <list key="key_attributes"/> </operator> <operator activated="true" class="join" compatibility="7.0.000-SNAPSHOT" expanded="true" height="82" name="Join (3)" width="90" x="1001" y="238"> <list key="key_attributes"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Subprocess" to_port="in 1"/> <connect from_op="Subprocess" from_port="out 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Sample (3)" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Sample" from_port="original" to_op="Materialize Data" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Materialize Data" from_port="example set output" to_op="Normalize (2)" to_port="example set input"/> <connect from_op="Normalize (2)" from_port="example set output" to_op="Sample (2)" to_port="example set input"/> <connect from_op="Sample (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Join (3)" to_port="left"/> <connect from_op="Sample (3)" from_port="example set output" to_op="Normalize (4)" to_port="example set input"/> <connect from_op="Normalize (4)" from_port="example set output" to_op="Rename (4)" to_port="example set input"/> <connect from_op="Rename (4)" from_port="example set output" to_op="Join (2)" to_port="left"/> <connect from_op="Retrieve Sonar (2)" from_port="output" to_op="Subprocess (2)" to_port="in 1"/> <connect from_op="Subprocess (2)" from_port="out 1" to_op="Materialize Data (2)" to_port="example set input"/> <connect from_op="Materialize Data (2)" from_port="example set output" to_op="Normalize (3)" to_port="example set input"/> <connect from_op="Normalize (3)" from_port="example set output" to_op="Sample (4)" to_port="example set input"/> <connect from_op="Sample (4)" from_port="example set output" to_op="Rename (3)" to_port="example set input"/> <connect from_op="Rename (3)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Join (2)" from_port="join" to_op="Join (3)" to_port="right"/> <connect from_op="Join (3)" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
