Hi all,
I tried to save the results of clustering to ms excel file but i face error .
Please have alook to this
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="210">
<list key="text_directories">
<parameter key="oo" value="D:\Classic_subset\test"/>
</list>
<operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="234" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="112" y="75">
<parameter key="attribute_name" value="metadata_file"/>
<operator activated="true" class="k_means" compatibility="5.3.013" expanded="true" height="76" name="Clustering" width="90" x="246" y="30">
<parameter key="max_runs" value="1"/>
<parameter key="max_optimization_steps" value="1"/>
<operator activated="true" class="write_excel" compatibility="5.3.013" expanded="true" height="76" name="Write Excel" width="90" x="380" y="75">
<parameter key="excel_file" value="C:\ssssss.xls"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="result 1"/>
</process>
</process>
