<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="5.3.001" expanded="true" height="60" name="Read Document" width="90" x="45" y="255"> <parameter key="file" value="myScriptFile.txt"/> <parameter key="use_file_extension_as_type" value="false"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.001" expanded="true" height="94" name="Process Documents" width="90" x="179" y="255"> <parameter key="create_word_vector" value="false"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <process expanded="true"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.013" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="165"> <parameter key="macro" value="myScript"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="text"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="execute_script" compatibility="5.3.013" expanded="true" height="76" name="Execute Script" width="90" x="246" y="75"> <parameter key="script" value="%{myScript}"/> </operator> <connect from_op="Read Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Execute Script" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
