Haddock...the article I have is a PDF published by Elsevier - Copyright © 2015 Elsevier Inc. That may be the same 2014 article as you listed or revised...and I would hope that the more recent one uses the latest RMStudio version...
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros> <macro> <key>futureMonths</key> <value>15</value> </macro> <macro> <key>horizon</key> <value>1</value> </macro> <macro> <key>windowSize</key> <value>6</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" breakpoints="after" class="read_csv" compatibility="6.0.003" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="/Users/carlosqa/Downloads/Dec 15 2014/10_TimeS_10.2.1_simpleTS.csv"/> <parameter key="column_separators" value=","/> <parameter key="date_format" value="MM/dd/yyyy"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Date.true.date.attribute"/> <parameter key="1" value="inputYt.true.real.attribute"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="179" y="30"> <parameter key="attribute_name" value="Date"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="inputYt"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples" width="90" x="179" y="210"> <parameter key="condition_class" value="no_missing_attributes"/> <list key="filters_list"/> </operator> <operator activated="true" breakpoints="after" class="series:windowing" compatibility="5.2.000" expanded="true" height="76" name="Windowing for Training" width="90" x="380" y="30"> <parameter key="window_size" value="%{windowSize}"/> <parameter key="create_label" value="true"/> <parameter key="label_attribute" value="inputYt"/> <parameter key="horizon" value="%{horizon}"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.2.000" expanded="true" height="76" name="Windowing for Application" width="90" x="380" y="120"> <parameter key="window_size" value="%{windowSize}"/> <parameter key="label_attribute" value="inputYt"/> </operator> <operator activated="true" class="vector_linear_regression" compatibility="6.5.002" expanded="true" height="76" name="Vector Linear Regression" width="90" x="514" y="30"/> <operator activated="true" class="extract_macro" compatibility="6.5.002" expanded="true" height="60" name="Extract Example Count" width="90" x="380" y="210"> <parameter key="macro" value="exampleCount"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_example_range" compatibility="6.5.002" expanded="true" height="76" name="Filter Example Range" width="90" x="380" y="300"> <parameter key="first_example" value="%{exampleCount}"/> <parameter key="last_example" value="%{exampleCount}"/> </operator> <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember" width="90" x="514" y="300"> <parameter key="name" value="data"/> </operator> <operator activated="true" class="loop" compatibility="6.5.002" expanded="true" height="76" name="Loop" width="90" x="514" y="165"> <parameter key="iterations" value="%{futureMonths}"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall" width="90" x="45" y="120"> <parameter key="name" value="data"/> </operator> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="multiply" compatibility="6.5.002" expanded="true" height="94" name="Multiply" width="90" x="447" y="30"/> <operator activated="true" class="materialize_data" compatibility="6.5.002" expanded="true" height="76" name="Materialize Data (2)" width="90" x="179" y="165"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Increase Date (2)" width="90" x="313" y="165"> <list key="function_descriptions"> <parameter key="Date" value="date_add(Date, 1, DATE_UNIT_MONTH)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="165"> <parameter key="attribute_name" value="prediction(label)"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes (3)" width="90" x="179" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="inputYt-5"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" compatibility="6.5.002" expanded="true" height="76" name="Rename" width="90" x="313" y="300"> <parameter key="old_name" value="inputYt-4"/> <parameter key="new_name" value="inputYt-5"/> <list key="rename_additional_attributes"> <parameter key="inputYt-3" value="inputYt-4"/> <parameter key="inputYt-2" value="inputYt-3"/> <parameter key="inputYt-1" value="inputYt-2"/> <parameter key="inputYt-0" value="inputYt-1"/> <parameter key="prediction(label)" value="inputYt-0"/> </list> </operator> <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember (2)" width="90" x="447" y="300"> <parameter key="name" value="data"/> </operator> <connect from_port="input 1" to_op="Apply Model" to_port="model"/> <connect from_op="Recall" from_port="result" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="output 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Materialize Data (2)" to_port="example set input"/> <connect from_op="Materialize Data (2)" from_port="example set output" to_op="Increase Date (2)" to_port="example set input"/> <connect from_op="Increase Date (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.5.002" expanded="true" height="76" name="Append" width="90" x="648" y="165"/> <connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Windowing for Training" to_port="example set input"/> <connect from_op="Windowing for Training" from_port="example set output" to_op="Vector Linear Regression" to_port="training set"/> <connect from_op="Windowing for Training" from_port="original" to_op="Windowing for Application" to_port="example set input"/> <connect from_op="Windowing for Application" from_port="example set output" to_op="Extract Example Count" to_port="example set"/> <connect from_op="Vector Linear Regression" from_port="model" to_op="Loop" to_port="input 1"/> <connect from_op="Extract Example Count" from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
earmijo wrote:I downloaded the code. The "unusual" operator are renamed operators. 1) Extract Example .. is an Extract Macro that extracts the number of examples. 2) Increase Data is a "Generate Attributes" operator that defines the variable "Date" as date_add(Date, 1, DATE_UNIT_MONTH)
