Text Mining How to remove particular phrases in pre-processing
mob
Whats the best way to remove repeated sentences from my documents during pre-processing ?
I have a example set that includes a "text" column and some other attributes. The text column was read in from files in a folder. The text itself has a number of repeated phrases that I "think" I should remove before mining as I think they would skew the word frequency.
Given the "Filter Stopwords (Dictionary)" can only remove 1 stopword per line how do I handle a case like wanting to remove "Assessment and Grading" but still keep the word assessment and the word grading if they are located elsewhere in the document and how do I expand it so I can add other sentences I need removed
Text Mining + NLP
MartinLiebig
Sounds like Remove Document Parts?
~Martin
mob
I thought that was for pulling out text I wanted to process further. Can I use it to dump repeated strings from the main text?
MartinLiebig
There is Remove and Keep Document Parts, one is throwing out parts of a document, the other keeps documents. Both can be configured with a regex.
If you have an example set with keywords, you can use aggregate with concat on it to generate a Regex. This is a bit the manual way, but i think it is doable.
~Martin
mob
Actually following testing my assumption about filter stopwords appears incorrect. You can add the entire phrase as a "stop word" 1 per line and it will be removed e.g. linguistic sentences.
