<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.5.002" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="Day" value="1"/> <parameter key="Month" value="2"/> <parameter key="Year" value="2015"/> <parameter key="Att1" value="23"/> <parameter key="Att2" value="27"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.5.002" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="Day" value="1"/> <parameter key="Month" value="2"/> <parameter key="Year" value="2015"/> <parameter key="Att3" value="29"/> <parameter key="Att4" value="30"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="join" compatibility="6.5.002" expanded="true" height="76" name="Join" width="90" x="246" y="120"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="Day" value="Day"/> <parameter key="Month" value="Month"/> <parameter key="Year" value="Year"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Join" to_port="left"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
