<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Deals" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="tree_to_rules" compatibility="6.5.002" expanded="true" height="76" name="Tree to Rules" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="parallel_decision_tree" compatibility="6.5.002" expanded="true" height="76" name="Decision Tree" width="90" x="112" y="120"/> <connect from_port="training set" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Deals-Testset" width="90" x="112" y="345"> <parameter key="repository_entry" value="//Samples/data/Deals-Testset"/> </operator> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="246" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.5.002" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="75"> <list key="function_descriptions"> <parameter key="Rule" value="MISSING_NOMINAL"/> <parameter key="Rule" value="if(missing(Rule), if(Age > 31.500 && Gender == "female" ,"if Age > 31.500 and Gender = female then no",MISSING_NOMINAL) ,Rule)"/> <parameter key="Rule" value="if(missing(Rule), if(Age > 31.500 && Gender == "male" && [Payment Method] == "cash" && Age > 35.500 ,"if Age > 31.500 and Gender = male and Payment Method = cash and Age > 35.500 then no" ,MISSING_NOMINAL) ,Rule)"/> <parameter key="Rule" value="if(missing(Rule), if(Age > 31.500 && Gender == "male" && [Payment Method] == "cash" && Age <= 35.500 ,"if Age > 31.500 and Gender = male and Payment Method = cash and Age ≤ 35.500 then yes" ,MISSING_NOMINAL) ,Rule)"/> <parameter key="Rule" value="if(missing(Rule), if(Age > 31.500 && Gender == "male" && [Payment Method] == "cheque" && Age > 35.500 ,"if Age > 31.500 and Gender = male and Payment Method = cheque and Age > 35.500 then no" ,MISSING_NOMINAL) ,Rule)"/> </list> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Tree to Rules" to_port="training set"/> <connect from_op="Tree to Rules" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Retrieve Deals-Testset" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="144"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
