Hi, I am using RapidMiner 6.5 with 1 year Academia license.
In my process I'm using Read Sparse Operator, here is my Process after exporting to XML:
<process version="6.5.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
<parameter key="parallelize_main_process" value="false"/>
<process expanded="true">
<operator activated="true" class="advanced_file_connectors:read_sparse" compatibility="6.5.002" expanded="true" height="60" name="Read Sparse" width="90" x="45" y="210">
<parameter key="format" value="no_label"/>
<parameter key="data_file" value="C:\Users\Kąputereg\Desktop\PROJEKT - RAPIDMINER\counted_2000_no_label.txt"/>
<parameter key="dimension" value="18635"/>
<parameter key="sample_size" value="-1"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="decimal_point_character" value="."/>
<list key="prefix_map"/>
<operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve 200k_SVM_Linear_C_0" width="90" x="45" y="75">
<parameter key="repository_entry" value="//Local Repository/data/Models/200k_SVM_Linear_C_0"/>
<operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="246" y="120">
<parameter key="create_view" value="false"/>
<connect from_op="Read Sparse" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Retrieve 200k_SVM_Linear_C_0" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
Now when I want to load it to my java application I get following error:
| INFO: <em class="error">The operator class 'advanced_file_connectors:read_sparse' is unknown. Possibly you must install a plugin for operators of group 'advanced_file_connectors'.</em> |
And my code:
public RapidMinerClassification(String pathToProcess) throws IOException, XMLException
System.setProperty("rapidminer.home", "C:\\Users\\Kąputereg\\.RapidMiner");
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
_rapidMinerProcess = new Process(new File(pathToProcess));
_readSparseOperator = _rapidMinerProcess.getOperator("Read Sparse");
public List<ClassificationResult> PredictSentimentalValue(String pathToCountedSparseFile) throws OperatorException
_readSparseOperator.setParameter(SparseFormatExampleSource.PARAMETER_DATA_FILE, pathToCountedSparseFile);
_rapidMinerProcess.run();
return null;
I think it may be related to fact that Read Sparse comes from Academia Lincese but I set right path to my RapidMiner home directory as indicated by:
INFO: rapidminer.home is 'C:\Users\Kąputereg\.RapidMiner'. Dec 25, 2015 5:56:08 PM com.rapidminer.core.license.ProductConstraintManager initialize INFO: Initializing license manager. Dec 25, 2015 5:56:08 PM com.rapidminer.core.license.ProductConstraintManager initialize INFO: Using default license location. Dec 25, 2015 5:56:08 PM com.rapidminer.core.license.ProductConstraintManager initialize INFO: License folder in RapidMiner Studio installation folder found. Also loading licenses from there. |
Any help would be appreciated.
EDIT: Fixed, for any future people with similar problem:
In Your RapidMiner Home directory create additional directory: lib\\plugins and copy all neccessery files there.
