"SOLVED: Simple word-count of wordlist from document."
User: "casnl"
New Altair Community Member
Updated by Jocelyn
Hi all,
I want to count the number of occurrences of 'positive' words in a set of 200 .txt files in 1 directory, seems simple but I'm not getting the results I'm expecting. And I think it has something to do with the way I'm reading my files.
Using the 'process documents from files' operator I'm accessing 200 .txt files from a single directory; in a second operator I try to create a wordlist from 1 .txt file (downloaded) containing 'positive words', I want to assess the number of occurrences of these positive words in my files. Basis processing applies (transform cases, stemming porter, tokenize and filter stopwords). However the output yields 0 occurrences in all 200 texts; which seems impossible. What am I missing here?
Thanks in advance.
<process version="5.3.013">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
       <list key="text_directories">
         <parameter key="Projects" value="/Users/casvanandel/Dropbox/Thesis/Data/ContentData/Projects"/>
       </list>
       <parameter key="create_word_vector" value="false"/>
       <parameter key="vector_creation" value="Term Frequency"/>
       <parameter key="keep_text" value="true"/>
       <parameter key="prune_below_absolute" value="2"/>
       <parameter key="prune_above_absolute" value="60"/>
         <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (2)" width="90" x="45" y="30"/>
         <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/>
         <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="179" y="30"/>
         <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="313" y="30"/>
         <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="30"/>
         <connect from_port="document" to_op="Transform Cases (2)" to_port="document"/>
         <connect from_op="Transform Cases (2)" from_port="document" to_op="Transform Cases" to_port="document"/>
         <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
         <connect from_op="Tokenize" from_port="document" to_op="Stem (Porter)" to_port="document"/>
         <connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
         <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
       </process>
     <operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="45" y="210">
         <parameter key="Positive" value="/Users/casvanandel/Dropbox/Thesis/Data/opinion-lexicon-English/pos"/>
       </list>
       <parameter key="use_file_extension_as_type" value="false"/>
       <parameter key="vector_creation" value="Binary Term Occurrences"/>
         <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (4)" width="90" x="45" y="30"/>
         <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (3)" width="90" x="179" y="30"/>
         <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (3)" width="90" x="313" y="30"/>
         <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (3)" width="90" x="447" y="30"/>
         <connect from_port="document" to_op="Transform Cases (4)" to_port="document"/>
         <connect from_op="Transform Cases (4)" from_port="document" to_op="Tokenize (3)" to_port="document"/>
         <connect from_op="Tokenize (3)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
         <connect from_op="Filter Stopwords (3)" from_port="document" to_op="Stem (3)" to_port="document"/>
         <connect from_op="Stem (3)" from_port="document" to_port="document 1"/>
       </process>
     <operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="120">
       <parameter key="vector_creation" value="Term Occurrences"/>
       <list key="specify_weights"/>
         <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (3)" width="90" x="45" y="30"/>
         <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="179" y="30"/>
         <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (2)" width="90" x="313" y="30"/>
         <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="447" y="30"/>
         <connect from_port="document" to_op="Transform Cases (3)" to_port="document"/>
         <connect from_op="Transform Cases (3)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
         <connect from_op="Tokenize (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
         <connect from_op="Stem (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
         <connect from_op="Filter Stopwords (2)" from_port="document" to_port="document 1"/>
       </process>
     <connect from_op="Process Documents from Files" from_port="example set" to_op="Process Documents from Data" to_port="example set"/>
     <connect from_op="Process Documents from Files (2)" from_port="word list" to_op="Process Documents from Data" to_port="word list"/>
     <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
   </process>
</process>
1 - 4 of 41
    User: "Andrew2"
    Hello
    Set the "create word vector" check box on the first process documents from files
    regards
    Andrew
    User: "casnl"
    OP
    Hi Andrew,
    Thanks for the feedback, however the process failed because: "The attribute abund was alredy present in the example set".
    Also; I take it I have to create a term occurrences word vector in the first process documents from files?
    Best,
    User: "Andrew2"
    Hello
    I had another look and realized what you were doing so my original suggestion was incorrect. If you use the Set Role operator on the output from the first Process Documents From Files and set the role of the text attribute to be regular, you should find that the final process documents operator will find the attribute and count the occurrences.
    There is an alternative method that needs one less Process Documents operator. If you connect the word list output to the first process documents operator and enable document vector creation and term occurrences within that, you should get the same answer.
    regards
    Andrew
    User: "casnl"
    OP
    Thanks for having another look! Helped me out.
    Cheers
