I am playing with imbalanced data (28 positive examples and 444 negative examples). I have randomly sampled 30 of the majority class merged with minority class and used it for learning. During the cross validation test step I have appended the remaining majority class sample to the test data set (retrieved from tes port) in order to test the model performance with imbalanced data.
The result of 2, 3, and 4 cross validation was reasonable the performance vector showed that it tested the model using 28 positive examples. However, with 5-cross validation and more things get weird. The performance showed that there are more positive examples than originally is in the data set. This is expected with the negative examples because I am using almost all of them in each iteration, however, the positive examples should add up to exactly the same number because in each iteration I am using only the portion provided by the tes port.
Can you help me please in explaining what I am doing wrong?
The data I used can be downloaded from
http://sci2s.ugr.es/keel/keel-dataset/datasets/imbalanced/imb_IRhigherThan9p1/page-blocks-1-3_vs_4.zip(csv format with few comment lines)
The code I use is
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve play imbalanced" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Local Repository/data/play imbalanced"/>
<operator activated="true" class="generate_id" compatibility="5.3.013" expanded="true" height="76" name="Generate ID" width="90" x="45" y="120"/>
<operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Multiply" width="90" x="45" y="345"/>
<operator activated="true" class="filter_examples" compatibility="5.3.013" expanded="true" height="76" name="Filter Examples (2)" width="90" x="246" y="345">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="att11=positive"/>
<parameter key="invert_filter" value="true"/>
<operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Multiply (2)" width="90" x="380" y="345"/>
<operator activated="true" class="sample" compatibility="5.3.013" expanded="true" height="76" name="Sample" width="90" x="581" y="345">
<parameter key="sample_size" value="30"/>
<list key="sample_size_per_class"/>
<list key="sample_ratio_per_class"/>
<list key="sample_probability_per_class"/>
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="multiply" compatibility="5.3.013" expanded="true" height="94" name="Multiply (3)" width="90" x="715" y="390"/>
<operator activated="true" class="set_minus" compatibility="5.3.013" expanded="true" height="76" name="Set Minus" width="90" x="581" y="660"/>
<operator activated="true" class="remember" compatibility="5.3.013" expanded="true" height="60" name="Remember" width="90" x="782" y="750">
<parameter key="name" value="NegDat"/>
<parameter key="io_object" value="ExampleSet"/>
<operator activated="true" class="filter_examples" compatibility="5.3.013" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="75">
<operator activated="true" class="append" compatibility="5.3.013" expanded="true" height="94" name="Append" width="90" x="581" y="120"/>
<operator activated="true" class="shuffle" compatibility="5.3.013" expanded="true" height="76" name="Shuffle" width="90" x="715" y="120"/>
<operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="916" y="75">
<parameter key="number_of_validations" value="6"/>
<operator activated="true" class="neural_net" compatibility="5.3.013" expanded="true" height="76" name="Neural Net" width="90" x="246" y="75">
<list key="hidden_layers"/>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="recall" compatibility="5.3.013" expanded="true" height="60" name="Recall" width="90" x="45" y="390">
<parameter key="remove_from_store" value="false"/>
<operator activated="true" class="append" compatibility="5.3.013" expanded="true" height="94" name="Append (2)" width="90" x="179" y="300"/>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="179" y="75">
<operator activated="true" class="performance" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="380" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Append (2)" to_port="example set 1"/>
<connect from_op="Recall" from_port="result" to_op="Append (2)" to_port="example set 2"/>
<connect from_op="Append (2)" from_port="merged set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Retrieve play imbalanced" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Generate ID" from_port="original" to_port="result 2"/>
<connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Sample" to_port="example set input"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Set Minus" to_port="example set input"/>
<connect from_op="Sample" from_port="example set output" to_op="Multiply (3)" to_port="input"/>
<connect from_op="Multiply (3)" from_port="output 1" to_op="Append" to_port="example set 2"/>
<connect from_op="Multiply (3)" from_port="output 2" to_op="Set Minus" to_port="subtrahend"/>
<connect from_op="Set Minus" from_port="example set output" to_op="Remember" to_port="store"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_op="Shuffle" to_port="example set input"/>
<connect from_op="Shuffle" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</process>
