hi,
is there any option to run thermal analysis on hyperelastic materials?
regards
Akash
hi, is there any option to run thermal analysis on hyperelastic materials? regards Akash
You can use the MATHE, choose your model (for instance Mooney Rivalin) and then use mechanic and thermal properties.
Best regards,
In MATHE, I dont see any option to enter Thermal conductivity. when i am trying to run the simulation, i am getting the following error.
akash
Do you want to perform a thermal - structural analysis ? or only thermal analysis ?
Because I don't understand the use of MATHE for thermal simulation ....
Currently only coefficient of thermal expansion (TEXP) can be added to MATHE card.
