"SOLVED: Performance Vector not showing / visible"
Fairly new to RM, I followed a couple tutorials. However neither the tutorials nor this forum could help me fix this issue. I followed this http://www.corequant.com/?p=1 tutorial step by step for Sentiment Analysis. Using RM 5.3.013 with (obviously) text processing extension. I never get the expected output, i.e. the Performance Vector. I am able to save the model and vector and apply it to unlabeled data; which yields results. However I want to know the performance of my model; what am I missing here? Why am I not getting any performance output?
My process:
My process:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Thanks in advance.
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="30">
<list key="text_directories">
<parameter key="negative" value="/Users/casvanandel/Dropbox/Thesis/Data/review_polarity/txt_sentoken/neg"/>
<parameter key="positive" value="/Users/casvanandel/Dropbox/Thesis/Data/review_polarity/txt_sentoken/pos"/>
</list>
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_above_percent" value="95.0"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="216" y="162"/>
<operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="292" y="247"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="421" y="338"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="313" y="30">
<operator activated="true" class="support_vector_machine_linear" compatibility="5.3.013" expanded="true" height="76" name="SVM (Linear)" width="90" x="112" y="30"/>
<connect from_port="training" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="51" y="56">
<operator activated="true" class="performance" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="99" y="165"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="store" compatibility="5.3.013" expanded="true" height="60" name="Store (2)" width="90" x="447" y="165">
<parameter key="repository_entry" value="//Local Repository/pd_model"/>
<operator activated="true" class="store" compatibility="5.3.013" expanded="true" height="60" name="Store" width="90" x="112" y="165">
<parameter key="repository_entry" value="//Local Repository/pd_word"/>
<operator activated="false" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve (2)" width="90" x="313" y="255">
<parameter key="repository_entry" value="pd_model"/>
<operator activated="false" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve" width="90" x="45" y="255">
<parameter key="repository_entry" value="pd_word"/>
<operator activated="false" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="179" y="345">
<parameter key="tbd" value="/yourdirectoy/txt_sentoken/tbd"/>
</list>
<operator activated="false" class="text:tokenize" compatibility="5.3.002" expanded="true" name="Tokenize (2)"/>
<operator activated="false" class="text:filter_by_length" compatibility="5.3.002" expanded="true" name="Filter Tokens (2)"/>
<operator activated="false" class="text:stem_porter" compatibility="5.3.002" expanded="true" name="Stem (2)"/>
<operator activated="false" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" name="Filter Stopwords (2)"/>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model (2)" width="90" x="514" y="300">
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Process Documents from Files" from_port="word list" to_op="Store" to_port="input"/>
<connect from_op="Validation" from_port="model" to_op="Store (2)" to_port="input"/>
<connect from_op="Store (2)" from_port="through" to_port="result 1"/>
<connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Retrieve" from_port="output" to_op="Process Documents from Files (2)" to_port="word list"/>
<connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/>
</process>
</process>
1 - 3 of
31
there is a slight piece missing on the screenshot of the tutorial: You need to connect the "ave" port of the 'Validation' operator to the process result ports, as you did with the "mod" port.
Marco
