<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Root"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="QUERY" value=""Moby_****""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="120"> <list key="attribute_values"> <parameter key="QUERY" value=""The_Adventures_of_Tom_Sawyer""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="210"> <list key="attribute_values"> <parameter key="QUERY" value=""Treasure_Island""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.005" expanded="true" height="112" name="Append" width="90" x="179" y="30"/> <operator activated="true" class="web:enrich_data_by_webservice" compatibility="5.3.001" expanded="true" height="60" name="MashUp" width="90" x="313" y="30"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="EXPLANATION" value="//h:div[@id='mw-content-text']/h:p[1]"/> </list> <list key="namespaces"/> <list key="index_queries"/> <parameter key="url" value="http://en.wikipedia.org/wiki/&lt;%QUERY%&gt;"/> <parameter key="delay" value="1000"/> <list key="request_properties"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.005" expanded="true" height="76" name="CleanUp" width="90" x="447" y="30"> <process expanded="true"> <operator activated="true" class="replace" compatibility="5.3.005" expanded="true" height="76" name="Replace" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="EXPLANATION"/> <parameter key="replace_what" value="<.*?>|\n"/> </operator> <operator activated="true" class="replace" compatibility="5.3.005" expanded="true" height="76" name="Replace (2)" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="EXPLANATION"/> <parameter key="replace_what" value="\s{2,}"/> <parameter key="replace_by" value=" "/> </operator> <operator activated="true" class="replace" compatibility="5.3.005" expanded="true" height="76" name="Replace (3)" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="EXPLANATION"/> <parameter key="replace_what" value="\s+([\,;\.\)\]\}])"/> <parameter key="replace_by" value="$1"/> </operator> <operator activated="true" class="replace" compatibility="5.3.005" expanded="true" height="76" name="Replace (4)" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="EXPLANATION"/> <parameter key="replace_what" value="([\(\[\{])\s+"/> <parameter key="replace_by" value="$1"/> </operator> <operator activated="true" class="replace" compatibility="5.3.005" expanded="true" height="76" name="Replace (5)" width="90" x="581" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="EXPLANATION"/> <parameter key="replace_what" value="\s*\[[0-9]+\]\s*"/> <parameter key="replace_by" value=" "/> </operator> <operator activated="true" class="order_attributes" compatibility="5.3.005" expanded="true" height="76" name="Reorder Attributes" width="90" x="715" y="30"> <parameter key="attribute_ordering" value="QUERY|EXPLANATION"/> </operator> <connect from_port="in 1" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Replace (3)" to_port="example set input"/> <connect from_op="Replace (3)" from_port="example set output" to_op="Replace (4)" to_port="example set input"/> <connect from_op="Replace (4)" from_port="example set output" to_op="Replace (5)" to_port="example set input"/> <connect from_op="Replace (5)" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_op="MashUp" to_port="Example Set"/> <connect from_op="MashUp" from_port="ExampleSet" to_op="CleanUp" to_port="in 1"/> <connect from_op="CleanUp" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
