I have a CSV data set with time attributes ("hh:mm:ss") in it, eg. attribute time1= "01:23:45" and time2 = "01:01:01"
I want to use GenerateAttribute (or some other Operator/Process) to calculate e.g. SumOfTime1AndTime2 (sholud be 02:24:46 in the example ).
How to to that?
I found that I can't simply add attributes of type time in GenerateAttribute. Then I have tried out several operator chains (NominalToDate (time), DateToNumeric and than GenerateAttribute and back to date..).
But nothing seems to work, because time seems to be handled internally as a date value.
Any ideas?
Here is an example which does not work:
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data_user_specification" compatibility="5.3.013" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="120">
<list key="attribute_values">
<parameter key="time1" value=""02:34:56""/>
<parameter key="time2" value=""01:01:01""/>
</list>
<operator activated="true" class="nominal_to_date" compatibility="5.3.013" expanded="true" height="76" name="Nominal to Date" width="90" x="179" y="120">
<parameter key="attribute_name" value="time1"/>
<parameter key="date_type" value="time"/>
<parameter key="date_format" value="hh:mm:ss"/>
<operator activated="true" class="nominal_to_date" compatibility="5.3.013" expanded="true" height="76" name="Nominal to Date (2)" width="90" x="313" y="120">
<parameter key="attribute_name" value="time2"/>
<operator activated="true" class="date_to_numerical" compatibility="5.3.013" expanded="true" height="76" name="Date to Numerical" width="90" x="447" y="120">
<parameter key="millisecond_relative_to" value="epoch"/>
<parameter key="keep_old_attribute" value="true"/>
<operator activated="true" class="date_to_numerical" compatibility="5.3.013" expanded="true" height="76" name="Date to Numerical (2)" width="90" x="581" y="120">
<operator activated="true" class="generate_attributes" compatibility="5.3.013" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="255">
<parameter key="SumOfBoth" value="time1_millisecond+time2_millisecond"/>
</list>
<operator activated="true" class="numerical_to_date" compatibility="5.3.013" expanded="true" height="76" name="Numerical to Date" width="90" x="179" y="255">
<parameter key="attribute_name" value="SumOfBoth"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Nominal to Date" to_port="example set input"/>
<connect from_op="Nominal to Date" from_port="example set output" to_op="Nominal to Date (2)" to_port="example set input"/>
<connect from_op="Nominal to Date (2)" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/>
<connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/>
<connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Numerical to Date" to_port="example set input"/>
<connect from_op="Numerical to Date" from_port="example set output" to_port="result 1"/>
</process>
</process>
[ /code]
