RapidMiner has stopped starting up
Hi appreciate your help on Win 7 32bit,
Was all working fine. (have uninstalled re-installed, deleted the .rapidminer file in \users\
gets to 'loading icons 'before existing on start up
Now rm.log file as follows
Oct 15, 2013 10:11:54 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
WARNING: Unable to create user home rapidminer directory C:\Users\Bruce\.RapidMiner5
Oct 15, 2013 10:11:54 PM com.rapidminer.RapidMiner performFirstInitialization
INFO: Performing upgrade to version 5.3.013
Oct 15, 2013 10:11:54 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Oct 15, 2013 10:11:55 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
Oct 15, 2013 10:11:55 PM com.rapidminer.tools.OperatorService init
INFO: Loading additional operators specified by rapidminer.operators.additional (${RAPIDMINER_OPERATORS_ADDITIONAL})
SEVERE: Cannot find operator description file ${RAPIDMINER_OPERATORS_ADDITIONAL}.
INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
Oct 15, 2013 10:11:55 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Oct 15, 2013 10:11:55 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
Oct 15, 2013 10:11:55 PM com.rapidminer.tools.jdbc.connection.DatabaseConnectionService writeXMLConnectionsEntries
WARNING: Cannot retrieve key, probably no one was created: java.io.IOException: Cannot retrieve key: C:\Users\Bruce\.RapidMiner5\cipher.key (The system cannot find the file specified)
at com.rapidminer.tools.cipher.KeyGeneratorTool.getUserKey(KeyGeneratorTool.java:118)
at com.rapidminer.tools.jdbc.connection.DatabaseConnectionService.writeXMLConnectionsEntries(DatabaseConnectionService.java:232)
at com.rapidminer.tools.jdbc.connection.DatabaseConnectionService.init(DatabaseConnectionService.java:83)
at com.rapidminer.RapidMiner.init(RapidMiner.java:568)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:241)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:560)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:541)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.rapid_i.Launcher.main(Launcher.java:346)
Oct 15, 2013 10:11:56 PM com.rapidminer.tools.cipher.KeyGeneratorTool createAndStoreKey
WARNING: Failed to delete old key file.
Have increased Java memory to 1024mb but was working on desktop icon before failing
any help much appreciated.
PS
If I run without deleting the .rapidminer file rm.log as follows
Oct 15, 2013 10:26:31 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: Found left-behind lock file from last startup at C:\Users\Bruce\.RapidMiner5\safeMode.lock.
Oct 15, 2013 10:26:31 PM com.rapidminer.tools.I18N <clinit>
Oct 15, 2013 10:26:33 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: com.rapidminer.gui.safemode.SafeMode.entering_safe_mode
Oct 15, 2013 10:26:33 PM com.rapidminer.tools.plugin.Plugin initAll
INFO: Plugins skipped.
Oct 15, 2013 10:26:33 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
Oct 15, 2013 10:26:34 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Oct 15, 2013 10:26:35 PM com.rapidminer.tools.OperatorService init
Oct 15, 2013 10:26:35 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
Oct 15, 2013 10:26:35 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
It will give option of starting in safe mode or ignoring but makes no difference as still existing, rm.log the same message.
Cybernife
