Could you please clarify,
Why Im getting different accuracies (performance vector result) for the same input supplied to two similar models.
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="467" width="748">
<operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
<operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="76" name="Multiply" width="90" x="45" y="120"/>
<operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="179" y="75">
<parameter key="attributes" value="attribute_14|attribute_15|attribute_16|attribute_17|attribute_18|attribute_19|attribute_2|attribute_22|attribute_23|attribute_24|attribute_25|attribute_26|attribute_27|attribute_28|attribute_29|attribute_3|attribute_30|attribute_31|attribute_32|attribute_33|attribute_34|attribute_38|attribute_39|attribute_40|attribute_41|attribute_42|attribute_50|attribute_53|attribute_55|attribute_56|attribute_57|attribute_58|attribute_59|attribute_60|attribute_7|attribute_6|attribute_8|attribute_35|attribute_20|attribute_5|attribute_54"/>
<operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply (2)" width="90" x="246" y="165"/>
<operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Validation (2)" width="90" x="380" y="30">
<process expanded="true" height="414" width="346">
<operator activated="true" class="decision_tree" compatibility="5.2.008" expanded="true" height="76" name="Decision Tree (2)" width="90" x="132" y="30"/>
<connect from_port="training" to_op="Decision Tree (2)" to_port="training set"/>
<connect from_op="Decision Tree (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.2.008" expanded="true" height="76" name="Performance (2)" width="90" x="200" y="30">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Validation (3)" width="90" x="380" y="165">
<process expanded="true" height="396" width="346">
<operator activated="true" class="decision_tree" compatibility="5.2.008" expanded="true" height="76" name="Decision Tree (3)" width="90" x="132" y="30"/>
<connect from_port="training" to_op="Decision Tree (3)" to_port="training set"/>
<connect from_op="Decision Tree (3)" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model (3)" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.2.008" expanded="true" height="76" name="Performance (3)" width="90" x="200" y="30">
<connect from_port="model" to_op="Apply Model (3)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/>
<connect from_op="Performance (3)" from_port="performance" to_port="averagable 1"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Validation (2)" to_port="training"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Validation (3)" to_port="training"/>
<connect from_op="Validation (2)" from_port="training" to_port="result 1"/>
<connect from_op="Validation (2)" from_port="averagable 1" to_port="result 2"/>
<connect from_op="Validation (3)" from_port="training" to_port="result 3"/>
<connect from_op="Validation (3)" from_port="averagable 1" to_port="result 4"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</process>
see my next post with similar kind of problem
