How to enable "Display Parameter" in PSIM
"Design Suites" -> "Display Parameter" is grayed and disable .
Please tell me how to create and display the table on the left side of the screen below in the same file , and how to directly modify the values in the table without opening a separate parameter file ?
In your attached picture, the parameters are displayed. This means that "Design Suites -> Display Parameter" is enabled, not disabled.
This picture does not show the problem "Design Suites" -> "Display Parameter" is grayed and disable.
Is this picture you want to achieve?
Please open either one of the design suite examples or a design suite template. The parameter panel will show up automatically.
Please use "Help >> Index" and type in the keyword "design suite" to get more information.
Sincerely,
Rhonda
0 -
Sorry , I didn't explain clearly and caused you to misunderstand .
Attached picture is the screenshot of a design suite example , but if I open a new file or other example , the "Display Parameter" function is grayed and disable .
I want to know if I open a non design suite example , how to generate an independent setting panel ( like "Display Parameter" displayed on the left side of the screen ) so that I don’t need to open the parameter file to modify it .
0 -
The parameter panel is for Design Suite only. The values you entered in this panel are used to design the controller for your PE system.
For other PSIM schematics, you need to enter the values in each element's parameter dialog.You may use a parameter file block to define some values and check the box to display them on screen.
You may change the values in the parameter file instead of each element's parameter dialog.
This simple example is:
Altair_PSIM_2024.0\examples\dc-dc\buck - main1.psimschPlease click the "Help" button in the FILE1 block to learn more about it.
0 -
Thanks for your reply .
Is there any chance to extend it to other PSIM schematics in the future ?
It is much more convenient to have an independent panel when setting parameters.0 -
Hi, Anil.
There is no plan to extend the parameter panel to other PSIM schematics.
You can see in hundreds of PSIM example circuits, there is no need to collect the parameter values in a panel.
Each PSIM schematic, if not in design suite mode, is a design of your own.
0 -
OK , Thanks for your reply .
