<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.6.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.6.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="open_file" compatibility="6.6.000-SNAPSHOT" expanded="true" height="68" name="Open File" width="90" x="45" y="34"> <parameter key="resource_type" value="URL"/> <parameter key="url" value="http://URL_TO_ZIP"/> </operator> <operator activated="true" class="loop_zipfile_entries" compatibility="6.6.000-SNAPSHOT" expanded="true" height="82" name="Loop Zip-File Entries" width="90" x="246" y="34"> <process expanded="true"> <operator activated="true" class="write_file" compatibility="6.6.000-SNAPSHOT" expanded="true" height="68" name="Write File" width="90" x="45" y="34"> <parameter key="filename" value="C:\Users\USER_NAME\Desktop\Test\%{file_name}"/> </operator> <connect from_port="file object" to_op="Write File" to_port="file"/> <connect from_op="Write File" from_port="file" to_port="out 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Open File" from_port="file" to_op="Loop Zip-File Entries" to_port="file"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
How would you do this without coding and using operators?
hi!
Did you have a look on Marco's process? This solves it in my eyes
~martin
