trivial question on a process (newbie)
lavramu
I created a process that takes in a file from disk (I used ProcessDocumentsFromFiles operator). Within (nested) that I created Tranformcases operator and ReplaceTokens. All the connections were given correctly and through breakpoints I saw that they were performing like I wanted.
Here is the question. After running the entire process..why is that I see the old text (without case transformation and replacement) in the example set in the results section while is see the actual processing of texts through breakpoints.
How do i see the output after all the transformation? When I connect the "wor" to res I seem to see the transformations in the final result. So what is the different between example set and wordlist set? when do you connect which to results?
And my main question is how to I see the transformed text? Even while writing to disk after transformation I see the text without any processing written.
This is the XML :
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="test" value="C:\Users\Uma\Desktop\nvivo\test"/>
<parameter key="high" value="C:\Users\Uma\Desktop\nvivo\High"/>
</list>
<parameter key="use_file_extension_as_type" value="false"/>
<parameter key="create_word_vector" value="false"/>
<parameter key="keep_text" value="true"/>
<operator activated="true" breakpoints="after" class="text:transform_cases" compatibility="5.3.001" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/>
<operator activated="true" breakpoints="after" class="text:replace_tokens" compatibility="5.3.001" expanded="true" height="60" name="Replace Tokens" width="90" x="179" y="30">
<list key="replace_dictionary">
<parameter key="reference.*coverage" value=" "/>
<parameter key="<Internals.*coverage]" value=" "/>
</list>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Replace Tokens" to_port="document"/>
<connect from_op="Replace Tokens" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Process Documents from Files" from_port="example set" to_port="result 1"/>
</process>
</process>
MariusHelf
Please don't double post. Closed.
