Hi all,
I am trying on the one-class libsvm on rapidminer. However, I received a problem states that "binominal label not supported". My label dataset has one type of label only. If I change the svm type to "C-SVC", it will pop a problem saying "SVM does not have sufficient capabilities for handling an example set with only one label". I've tried several data type and I saw this thread
http://rapid-i.com/rapidforum/index.php/topic,1596.0.html but it does not help much in my case.
I am quite new in using rapidminer.
Please help ??? ???
Thank you.
