Process documents from data generates 2 times the data
Hi all,
I'm new with rapidminer and tried to read rss feeds and put it in some files like this tutorial on vimeo (https://vimeo.com/62963128). Almost everything works, but I have one problem. The process generates every file twice. File 1 and 21 are the same file, file 2 and 22 are the same file, and so on. Does anybody knows what I'm doing wrong?
Dave
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Thanks in advance.
<process version="6.5.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="web:read_rss" compatibility="6.5.000" expanded="true" height="60" name="Read RSS Feed" width="90" x="112" y="255">
<parameter key="url" value="http://www.autoblog.com/category/recap/rss.xml"/>
<parameter key="random_user_agent" value="true"/>
<parameter key="connection_timeout" value="10000"/>
<parameter key="read_timeout" value="10000"/>
<operator activated="true" class="web:retrieve_webpages" compatibility="6.5.000" expanded="true" height="60" name="Get Pages" width="90" x="514" y="435">
<parameter key="link_attribute" value="Link"/>
<parameter key="page_attribute" value="myhtml"/>
<parameter key="random_user_agent" value="false"/>
<parameter key="follow_redirects" value="true"/>
<parameter key="accept_cookies" value="none"/>
<parameter key="cookie_scope" value="global"/>
<parameter key="request_method" value="GET"/>
<parameter key="delay" value="none"/>
<parameter key="delay_amount" value="1000"/>
<parameter key="min_delay_amount" value="0"/>
<parameter key="max_delay_amount" value="1000"/>
<operator activated="true" class="text:process_document_from_data" compatibility="6.5.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="715" y="345">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="false"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
<operator activated="true" class="web:extract_html_text_content" compatibility="6.5.000" expanded="true" height="60" name="Extract Content" width="90" x="112" y="30">
<parameter key="extract_content" value="true"/>
<parameter key="minimum_text_block_length" value="5"/>
<parameter key="override_content_type_information" value="true"/>
<parameter key="neglegt_span_tags" value="true"/>
<parameter key="neglect_p_tags" value="true"/>
<parameter key="neglect_b_tags" value="true"/>
<parameter key="neglect_i_tags" value="true"/>
<parameter key="neglect_br_tags" value="true"/>
<parameter key="ignore_non_html_tags" value="true"/>
<operator activated="true" class="web:unescape_html" compatibility="6.5.000" expanded="true" height="60" name="Unescape HTML Document" width="90" x="313" y="30"/>
<operator activated="true" class="text:write_document" compatibility="6.5.000" expanded="true" height="76" name="Write Document" width="90" x="514" y="30">
<parameter key="overwrite" value="true"/>
<operator activated="true" class="write_file" compatibility="6.5.002" expanded="true" height="60" name="Write File" width="90" x="715" y="165">
<parameter key="resource_type" value="file"/>
<parameter key="filename" value="d:\test\%{t}-%{a}.txt"/>
<parameter key="mime_type" value="application/octet-stream"/>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Unescape HTML Document" to_port="document"/>
<connect from_op="Unescape HTML Document" from_port="document" to_op="Write Document" to_port="document"/>
<connect from_op="Write Document" from_port="document" to_port="document 1"/>
<connect from_op="Write Document" from_port="file" to_op="Write File" to_port="file"/>
</process>
<connect from_op="Read RSS Feed" from_port="output" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
</process>
</process>
Dave
Comments
No comments on this post.
