<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel" width="90" x="112" y="30"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel (2)" width="90" x="112" y="120"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel (3)" width="90" x="112" y="210"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel (4)" width="90" x="112" y="480"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel (5)" width="90" x="112" y="300"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel (6)" width="90" x="112" y="390"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="append" compatibility="5.3.013" expanded="true" height="166" name="Append" width="90" x="514" y="210"/> <operator activated="true" class="write_database" compatibility="5.3.013" expanded="true" height="60" name="Write Database" width="90" x="715" y="210"/> <connect from_op="Read Excel" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Read Excel (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Read Excel (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Read Excel (4)" from_port="output" to_op="Append" to_port="example set 6"/> <connect from_op="Read Excel (5)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Read Excel (6)" from_port="output" to_op="Append" to_port="example set 5"/> <connect from_op="Append" from_port="merged set" to_op="Write Database" to_port="input"/> <connect from_op="Write Database" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
