I've been trying (unsucessfully so far) to place an operator "Execute R" inside a X-validation operator and get the performance metric (this I can) and the model output (say the regression coefficients--this I can't).
<process version="6.5.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Polynomial" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Polynomial"/>
<description align="center" color="blue" colored="true" width="126">Fetch example data</description>
<operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation" width="90" x="581" y="120">
<operator activated="true" class="r_scripting:execute_r" compatibility="6.5.000" expanded="true" height="76" name="Learn Model" width="90" x="246" y="120">
<parameter key="script" value="# train a linear model on the training data and return the learned model rm_main = function(data) { 	linearModel <- lm(formula =label ~ . , data =data) 	return(linearModel) } "/>
<description align="center" color="red" colored="true" width="126">Train a linear model in R and return it as an R object</description>
<connect from_port="training" to_op="Learn Model" to_port="input 1"/>
<connect from_op="Learn Model" from_port="output 1" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="r_scripting:execute_r" compatibility="6.5.000" expanded="true" height="94" name="Apply R Model" width="90" x="112" y="75">
<parameter key="script" value="## load the trained model and apply it on the test data rm_main = function(model, data) { # apply the model and build a prediction result <-predict(model, data) # add the prediction to the example set data$prediction <- result # update the meta data metaData$data$prediction <<- list(type="real", role="prediction") return(data) } "/>
<description align="center" color="red" colored="true" width="126">Apply the trained model on the test data</description>
<operator activated="true" class="performance" compatibility="6.5.002" expanded="true" height="76" name="Performance" width="90" x="313" y="75"/>
<connect from_port="model" to_op="Apply R Model" to_port="input 1"/>
<connect from_port="test set" to_op="Apply R Model" to_port="input 2"/>
<connect from_op="Apply R Model" from_port="output 1" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Retrieve Polynomial" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 2"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</process>
