<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Deals" width="90" x="112" y="210"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="false" class="productivity:execute_process" compatibility="6.5.002" expanded="true" height="60" name="Execute Segmentation Process" width="90" x="313" y="435"> <parameter key="process_location" value="//Local Repository/Forum/KCD43/processes/Segmentation Process"/> <list key="macros"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.5.002" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="210"> <list key="function_descriptions"> <parameter key="Segment" value="if(Age < 50, "Young","Old")"/> </list> </operator> <operator activated="true" class="set_role" compatibility="6.5.002" expanded="true" height="76" name="Set Role" width="90" x="380" y="210"> <parameter key="attribute_name" value="Segment"/> <parameter key="target_role" value="cluster"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="multiply" compatibility="6.5.002" expanded="true" height="94" name="Multiply" width="90" x="514" y="210"/> <operator activated="true" class="remove_duplicates" compatibility="6.5.002" expanded="true" height="76" name="Remove Duplicates" width="90" x="648" y="345"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Segment"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember" width="90" x="782" y="345"> <parameter key="name" value="Segments"/> </operator> <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation" width="90" x="916" y="120"> <process expanded="true"> <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall" width="90" x="45" y="30"> <parameter key="name" value="Segments"/> <parameter key="remove_from_store" value="false"/> <description align="center" color="transparent" colored="false" width="126">Only to keep track</description> </operator> <operator activated="true" class="extract_macro" compatibility="6.5.002" expanded="true" height="60" name="Extract Macro (4)" width="90" x="179" y="30"> <parameter key="macro" value="numberOfSegments"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop" compatibility="6.5.002" expanded="true" height="94" name="Loop" width="90" x="246" y="120"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="%{numberOfSegments}"/> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="6.5.002" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="currentSegment"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Segment"/> <parameter key="example_index" value="%{iteration}"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.5.002" expanded="true" height="94" name="Filter Examples" width="90" x="380" y="165"> <list key="filters_list"> <parameter key="filters_entry_key" value="Segment.equals.%{currentSegment}"/> </list> </operator> <operator activated="true" class="parallel_decision_tree" compatibility="6.5.002" expanded="true" height="76" name="Decision Tree" width="90" x="581" y="165"/> <connect from_port="input 1" to_op="Extract Macro" to_port="example set"/> <connect from_port="input 2" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="126"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="training" to_op="Loop" to_port="input 2"/> <connect from_op="Recall" from_port="result" to_op="Extract Macro (4)" to_port="example set"/> <connect from_op="Extract Macro (4)" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="model"/> <portSpacing port="source_training" spacing="108"/> <portSpacing port="sink_model" spacing="90"/> <portSpacing port="sink_through 1" spacing="36"/> </process> <process expanded="true"> <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall (2)" width="90" x="45" y="30"> <parameter key="name" value="Segments"/> <parameter key="remove_from_store" value="false"/> <description align="center" color="transparent" colored="false" width="126">Only to keep track</description> </operator> <operator activated="false" class="loop_clusters" compatibility="6.5.002" expanded="true" height="112" name="Loop Clusters (2)" width="90" x="179" y="435"> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="6.5.002" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="30"> <parameter key="macro" value="currentSegment"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Segment"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.5.002" expanded="true" height="94" name="Filter Examples (2)" width="90" x="246" y="165"> <list key="filters_list"> <parameter key="filters_entry_key" value="Segment.equals.%{currentSegment}"/> </list> </operator> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="514" y="75"> <list key="application_parameters"/> </operator> <connect from_port="cluster subset" to_op="Extract Macro (2)" to_port="example set"/> <connect from_port="in 1" to_op="Apply Model" to_port="model"/> <connect from_port="in 2" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="out 1"/> <portSpacing port="source_cluster subset" spacing="0"/> <portSpacing port="source_in 1" spacing="54"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop" compatibility="6.5.002" expanded="true" height="112" name="Loop (2)" width="90" x="246" y="120"> <parameter key="set_iteration_macro" value="true"/> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="6.5.002" expanded="true" height="60" name="Extract Macro (3)" width="90" x="112" y="30"> <parameter key="macro" value="currentSegment"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Segment"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.5.002" expanded="true" height="94" name="Filter Examples (3)" width="90" x="380" y="255"> <list key="filters_list"> <parameter key="filters_entry_key" value="Segment.equals.%{currentSegment}"/> </list> </operator> <operator activated="true" class="select" compatibility="6.5.002" expanded="true" height="60" name="Select" width="90" x="380" y="165"> <parameter key="index" value="%{iteration}"/> </operator> <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model (2)" width="90" x="648" y="165"> <list key="application_parameters"/> </operator> <operator activated="false" breakpoints="before" class="parallel_decision_tree" compatibility="6.5.002" expanded="true" height="76" name="Decision Tree (2)" width="90" x="581" y="390"/> <connect from_port="input 1" to_op="Extract Macro (3)" to_port="example set"/> <connect from_port="input 2" to_op="Select" to_port="collection"/> <connect from_port="input 3" to_op="Filter Examples (3)" to_port="example set input"/> <connect from_op="Filter Examples (3)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Select" from_port="selected" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="108"/> <portSpacing port="source_input 3" spacing="36"/> <portSpacing port="source_input 4" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.5.002" expanded="true" height="76" name="Append" width="90" x="380" y="120"/> <operator activated="true" class="performance_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance" width="90" x="581" y="120"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Loop (2)" to_port="input 2"/> <connect from_port="test set" to_op="Loop (2)" to_port="input 3"/> <connect from_op="Recall (2)" from_port="result" to_op="Loop (2)" to_port="input 1"/> <connect from_op="Loop (2)" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="90"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/> <connect from_op="Multiply" from_port="output 2" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Validation" from_port="model" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <description align="center" color="yellow" colored="false" height="178" resized="true" width="263" x="232" y="134">Do the segmentation (also possible via clustering)</description> <description align="center" color="yellow" colored="false" height="193" resized="true" width="323" x="620" y="272">Store an example per segment to keep track</description> </process> </operator></process>
