<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.6.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.6.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.6.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Deals" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.6.000-SNAPSHOT" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34"> <list key="function_descriptions"> <parameter key="Rating" value="if(matches([Payment Method], ".*cheque.*"), "bad", "good")"/> </list> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
