k-nn clasifier
ArnoG
I am using a K-nn clasifier to perform a sentiment analysis on review texts. I export the results to an excel sheet. For every month (cumlative) I create a bar graph showing the results, Basically the bar graph shows the # of positive and negative reviews.
But till my suprise the results of the sentiment analysis difference per month. For the sentiment analysis I am using exacrly the same model, and exactly the same data & training set. When I run the analyses for january a certain review is labeled positive, when I run the same analyses till february, the same review in january is now labeled as negative.
Is there a way to prefend this?
Best regards,
Arno
RalfKlinkenberg
Hi Arno,
Are you sure that you use exactly the same training data set for both applications of k-NN in January and February?
If you share your RapidMiner process, we could better check for the reason for this process behaviour.
Best regards,
Ralf
ArnoG
Hi Ralf,
Thanks for your response!
I am completely sure that I didn't change the training set.
As an example I used following process:
<process version="6.0.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="6.0.003" expanded="true" height="60" name="Results" width="90" x="45" y="210">
<parameter key="excel_file" value="C:\Improve Your Business\Qing\Rapidminer\testing knn.xls"/>
<parameter key="sheet_number" value="2"/>
<parameter key="imported_cell_range" value="A1:A18"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="Test reviews.true.text.attribute"/>
</list>
<operator activated="true" class="select_attributes" compatibility="6.0.003" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="210">
<parameter key="attributes" value="text|sent|Review|Prijs|Test reviews"/>
<operator activated="true" class="set_role" compatibility="6.0.003" expanded="true" height="76" name="Set Role" width="90" x="514" y="210">
<parameter key="attribute_name" value="Test reviews"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="648" y="210">
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="999"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="112" y="30"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (4)" width="90" x="246" y="30"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.002" expanded="true" height="76" name="Filter Stopwords (4)" width="90" x="380" y="30">
<parameter key="file" value="C:\Improve Your Business\Qing\Rapidminer\nederlandse stopwoordenlijst.txt"/>
<operator activated="false" class="text:stem_snowball" compatibility="5.3.002" expanded="true" height="60" name="Stem (4)" width="90" x="514" y="120">
<parameter key="language" value="Dutch"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (3)" width="90" x="648" y="30">
<parameter key="min_chars" value="2"/>
<operator activated="false" class="text:generate_n_grams_terms" compatibility="5.3.002" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="782" y="120"/>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (4)" to_port="document"/>
<connect from_op="Transform Cases (4)" from_port="document" to_op="Filter Stopwords (4)" to_port="document"/>
<connect from_op="Filter Stopwords (4)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
<connect from_op="Filter Tokens (3)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="read_excel" compatibility="6.0.003" expanded="true" height="60" name="Training set" width="90" x="45" y="30">
<parameter key="imported_cell_range" value="A1:B243"/>
</list>
<parameter key="0" value="Prijs.true.text.attribute"/>
<parameter key="1" value="B.true.polynominal.label"/>
</list>
<operator activated="true" class="select_attributes" compatibility="6.0.003" expanded="true" height="76" name="Select Attributes (2)" width="90" x="313" y="30">
<parameter key="attributes" value="sent|text|training set|sen|Prijs"/>
<operator activated="true" class="set_role" compatibility="6.0.003" expanded="true" height="76" name="Set Role (2)" width="90" x="514" y="30">
<parameter key="attribute_name" value="Prijs"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="648" y="30">
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30">
<parameter key="characters" value=".:?!"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="179" y="30"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.002" expanded="true" height="76" name="Filter Stopwords (3)" width="90" x="313" y="30">
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="581" y="30">
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
<connect from_op="Filter Stopwords (3)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="k_nn" compatibility="6.0.003" expanded="true" height="76" name="k-NN (2)" width="90" x="782" y="30">
<parameter key="k" value="3"/>
<parameter key="weighted_vote" value="true"/>
<parameter key="measure_types" value="NumericalMeasures"/>
<parameter key="numerical_measure" value="CosineSimilarity"/>
<operator activated="true" class="apply_model" compatibility="6.0.003" expanded="true" height="76" name="Apply Model (2)" width="90" x="916" y="120">
<connect from_op="Results" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/>
<connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Training set" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="k-NN (2)" to_port="training set"/>
<connect from_op="k-NN (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/>
</process>
</process>
I run the process for data till april and one till may.
Images below shows the results from running the two datasets
Till April
Till May:
As you can see is the review "goede prijs" in the run till april predicted neg and in the run till may pos.
I used exactly the same RM process and exactly the same training data.
How can I get different results?
Best Regards,
Arno
